![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Baffled by annoying Squeaking Sound
I've had this since last year. I first thought it was the sway bar bushings, or suspension, but they are all fine. I changed two motor mounts that were bad and though they might be the problem, and I'm still getting this issue.
It happens when you put the car in D or shift into R. The transmission shifts fine. I replaced the transmission fluid with full synthetic WS compatible last spring at 50k. The sound usually stays there and comes back and goes. Sometimes you hear it over bumps or when you accelerate |
| Tags |
| coolant, mounts, transmission |
| Yaris Sedan Deadening and Sound system upgrade | derickveliz2 | In Car Entertainment + Electronics (audio / video / alarm) | 2992 | 11-18-2021 03:14 AM |
| Finally found the answer to the annoying ticking/rattling sound from inside... | YarisSedan | General Yaris / Vitz Discussion | 2 | 05-10-2012 06:39 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-05-2011 12:56 AM |
| Squeaking Sound underneath 2008 Toyota Yaris Sedan Automatic | SDYarisGuy | DIY / Maintenance / Service | 3 | 02-27-2011 06:36 AM |
| That annoying ding sound! GRRRRR! | KnytewolF | General Yaris / Vitz Discussion | 4 | 01-13-2009 02:25 AM |
