Old 11-11-2024, 02:58 PM   #1
medion65
Drives: 2000 Yaris Verso 1,3 petrol
Yaris 1,3 petrol with hesitation problem
Thanks for the membership. Hope there are someone who can help me with my first Toyota ever. It is a 2000 Verso 1,3 petrol. It runs just fine on idle or maybe a little high. When i try to rev it up it hesitates but if i very carefully revs it up it becomes normal again. It also after a while throws the P0172 code meaning it runs too rich. Both O2 sensors are new, spark plugs and air filter also and i have checked for vacuum leaks everywhere. I hooked up the computer to see what kind of measurements the O2 sensors shows and it was some strange readings. The voltage on both sensors at idle is about 0,9V and google says thats ok but the strange reading is the B1-S1 short fuel term reads -20,3 at idle and the B2-S2 short term fuel shows "0" (no reading). Any help will be much appreciated. The emission is to high so i have to postspone the MOT until i can find the reason.
medion65 is offline   Reply With Quote
Old 11-12-2024, 11:19 AM   #2
thetut
Drives: 2007 4dr sedan
Try cleaning the MAF sensor with the appropiate cleaning fluid. If it is dirty it will be reporting the wrong airflow.
thetut is offline   Reply With Quote
Super weird Yaris 2003 A/C problem zoharby DIY / Maintenance / Service 13 06-22-2017 12:14 PM
Yaris Reverse Problem - Automatic fowmd887 General Yaris / Vitz Discussion 3 06-28-2012 07:11 AM
