![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
car slow af still...
i wanted to make my yaris fully mod with stage 1 and see how fast it goes..
stage 1: none internal parts - intake, spacer with polished TB - jdm vitz rs counter parts, vvti solenoid, maf etc. ix plugs - exhaust system -header, center pipe - lightweight pulley - 1jz injectors with E85 conversion - ecu chip tuned..tuned all the to the maximum performance..lol 😅😅😅😅 result...slow af..still..probably gained 15-20whp..not enough 😂😂😂😂😂 feels like driving 4age engine where i have to rev high rpm all the time... 😧😧😧😧😧 next mod: forged piston or pair of jun cam 😤😤😤😤 ![]() Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
You gained zero HP. spacer and polished TB did nothing. 1ZZ TB and mod your intake or do an intake swap plus complete exhaust from header to tail pipe you'll get a better throttle response. other then that boost or piston swap with fuel management. These engines especially the head is not designed for high performance but fuel efficiency. So unless you spend money to boost your gonna get disappointed.
Theirs no replacement for displacement!!!! |
#3 | |
going to try out prius piston.. Sent from my SM-J700F using Tapatalk
![]() Drives: Ncp42 Join Date: Jan 2016
Honestly adding a throttle body spacer isn't going to do much cause all it does is increase the length between throttle body and the intake but still by doing that you will increase about 0.5 amount of torque at low rpm i believe,i change my throttle body to 1zz-fe and custom made a spacer cause my intake manifold is 3 hole and the 1zz-fe is 4 hole,than custom made a short ram intake my self[some clamps and a samco hose lol],i can feel the torque came in early but doesn't effect much in high rpm...if my butt dyno is correct i say increase 60% in low rpm 30%in mid and 10%in high....but still the 1zz-fe throttle body is 60mm and stock 1nz fe is around 46mm by porting it i think you can get to 47mm maybe?wouldn't change much.
But what crank pulley you use?and how much cc does the 1jz have?can i use that injector with only ron95 fuel? |
#5 | |
feed my pet
actually TB polishing with TB spacers do work. racing team called BRD actually gained hp with this set up. theyre big manufacturer and i dont think their stupid enough to do mass production on spacer+polishing. BRD does not waste time mass producing product. i know there is going to be a key board warriors who will claim things without any mods in their yaris 😂😂😂😂😂
#8 | |
Sent from my 3006 using Tapatalk |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
Converting to E85 on stock pistons, with your current mods, regardless of how much tuning you've done will yield no significant gains in power. You might have even lost power, just my $0.02 from a keyboard warrior, what do I know...
#10 | |
only converting to E85 doesnt do anything..they actually have E85 conversion just to change the fuel module with E85 plugs for stock injectors but changing to larger injector and slight timing advance on ecu do gain hp.. E85 tuning isnt same mod as putting on cold air intake and gaining 5hp with sound effects..lol 😂😂😂 Sent from my SM-J700F using Tapatalk
they give 2 options down here..either 1zz 60mm TB or polishing stock TB and spacers (they come as package)...
people who are going all out with custom manifold and intake choose 60mm TB.. i chose polishing and spacer because..i just felt like it 😂😂😂 Sent from my SM-J700F using Tapatalk
#12 | |
#13 | |
here is video of only E85 + timing advance only with dyno...lol...15hp? rofl.. keyboard racer these days, write like they actually have the mods in their yarus..😂😂😂😂😂 goto youtube and search "vios e85" or "yaris e85"..most of the videos will have standard e85 + timing advance tuning(basic).. Sent from my SM-J700F using Tapatalk
#14 | |
#15 | |
put some photos of your car..bet you got some turbo whistler on your exhaust 😂😂😂😂 Sent from my SM-J700F using Tapatalk
I saw the dyno charts that is why I said 23hp measured at the hubs. Stock didn't come with a turbo, but that car appears to have a boost gauge??? Lol
#17 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
No offence to the OP, but what are you comparing your car to, in order to reach the conclusion that it's "slow af"? It's important to keep things real, and compare apples to apples. If you try to compare your Yaris to a BMW or Audi, then you'll definitly be dissapointed.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
| ImportRacer88's Photo Scavenger Hunt | ImportRacer88 | General Yaris / Vitz Discussion | 8 | 02-28-2012 05:19 AM |
| Car Buying Scams | nemelek | Off-topic / Other Cars / Everything else Discussions | 1 | 09-29-2011 09:01 PM |
| Jerkratt - Photo Scavenger Hunt | Jerkratt | Photo-Video-Media Gallery | 3 | 03-04-2009 10:03 AM |
