Old 03-27-2018, 07:55 AM   #1
Other Cars A Supra
Drives: 08 Yaris D4D, Supra, VW Camper
Wheel fitment really isnt my strong point
I am sorry guys to have to ask but wheel fitment is not one i can do!
(give me an engine swap, fuel system and turbo set up to do any day!!!)
I know which wheels i want but cant work out if they will fit ok and what sort of tire size to go with. i am also lowering by 35mm front, 30mm rear on TEIN Springs.
These are the wheels i am after, any advice on if they will fit ok and what size tire to go with would be great. happy to have a small amount of stretch on the tire also.
Borbet
4 x 100 stud pattern
15 inch rim diameter
7j rim width
38 ofset
they also do them with a 30 ofset
Other Cars A Supra is offline   Reply With Quote
Old 03-27-2018, 08:19 AM   #2
alias06
Drives: 2008 Red Toyota Yaris
Based off those specs, the wheels should fit fine. I've got XXR 522s which are 15x7 +22? with no issues. I'm not lowered, but there shouldn't be any issues either even with a 1-2 inch drop. On the wheels I have the stock 185/60r15s, but I have fit a 205/45r17 in there with no issues. I'd go 205/55r15s for tires, they are going to be a little bigger in overall diameter, but it should give you better tire options.
alias06 is offline   Reply With Quote
Old 03-27-2018, 10:03 AM   #3
tmontague
tmontague's Avatar
You will be fine, that was my set up before I rolled my fenders and went with wider rims.
Worst case scenario you can get camber bolts up front to give yourself some very minor negative camber. I suspect you won't have to as I had no issue with rubbing on the track with a wider set up (+24 offset on 205 wide rubber) and I had a moderate -2.5 up front
Old 03-27-2018, 12:44 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
The 38's will work well with the drop and 205mm rubber.
Old 03-28-2018, 11:02 AM   #5
Other Cars A Supra
thanks guys this is really helpful. wheel fitment seriously isnt my strong point. i know what the numbers and letters mean but even with the online tools im still never convinced ill get it right!
Old 03-29-2018, 02:26 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If you're more into "stance", go 15x7 offset 30 with 175/50/15 tires.
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 05:20 PM
Spring, wheel and tire fitment ddeschen Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-23-2014 10:36 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Wheel Fitment Question PuntCuncher Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 11-06-2009 04:14 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
