Old 03-10-2018, 08:50 PM   #1
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Finally hopped on the sway bar bandwagon!
So I finally caved and bought one! I'm gonna have my friend drive my car before and after the install because he's curious to see how it will affect the vehicles performance. Putting this bad boy on tomorrow!
m.flores.0928 is offline   Reply With Quote
Old 03-10-2018, 09:22 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Nice! I so want to do this to my 2006 RS. Looking forward to your and your friend's impressions.
Old 03-10-2018, 09:28 PM   #3
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
its a nice lookin' piece
too bad you dont see much of it after installation
Old 03-10-2018, 09:39 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
One of the best mods you can do to this car IMHO.
Old 03-10-2018, 09:44 PM   #5
m.flores.0928
Drives: 2014 Yaris
Yea that's what I keep hearing! I've done a lot of miscellaneous electrical stuff like interior lights and a light bar in the bumper but I haven't done anything to actually improve driving performance lol
Old 03-11-2018, 12:58 AM   #6
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I definitely noticed the difference. It's the best mod you can make to a Yaris of any trim level with stock/factory suspension.
Kalispel is offline   Reply With Quote
Old 03-11-2018, 03:07 PM   #7
m.flores.0928
Drives: 2014 Yaris
Damn that was so easy! Road test results coming shortly! I'm sure you guys already know what the transformation is like though
Old 03-11-2018, 03:34 PM   #8
06YarisRS
I'm wondering how the bar can be housed in the rear axle beam without causing clunking or some form of contact noise. I guess it's been designed in a way not to. One of the kits I looked at had bushings and U-clamps which attach to the beam. The other one I looked at - like yours - doesn't seem to have any secure attachment to the beam.
Your installation looks great. Awaiting the driving impressions.
Old 03-11-2018, 03:42 PM   #9
m.flores.0928
Drives: 2014 Yaris
I'm wondering how the bar can be housed up into the rear axle beam without causing clunking or some form of contact noise. I guess it's been designed in a way not to. One of the kits I looked at had bushings and U-clamps which attach to the beam. The other one I looked at - like yours - doesn't seem to have any secure attachment to the beam.
It's a very clever design from TRD. Props to them. It just sits there under the beam and I heard no noise. It bolts to the shock mount as well as a second empty bolt hole that was already there.
Massive difference. Night and day. It doesn't feel floaty, it doesn't roll hardly at all and the front end doesn't push nearly as much as it used to. I even noticed in a parking lot as I intentionally went over an aggressive speed bump at an angle at like 7mph.
Old 03-22-2018, 06:40 AM   #10
SECProto
Drives: 2012 Yaris LE
Thanks for the super clear photos of the install! will be super helpful if i (or others) decide to do this. Which brings me to a couple quick questions...
I'm not much of a performance guy, so i was curious about this - does it actually change the driving performance in any way (increase/decrease traction, for example)? or is it just for the feeling to the occupant (softer/harder bumps, car leaning more/less on corners)? i've never really had an issue with the feel of the ride in my '12 and i don't know anyone who has one with this mod that i could try.
SECProto is offline   Reply With Quote
Old 03-23-2018, 01:39 PM   #11
m.flores.0928
Drives: 2014 Yaris
Sorry for the delay on responses, I've been super busy.
The sway bar increases oversteer and keeps the car more flat in the corners. Less front end push, less body roll
Old 03-11-2018, 04:16 PM   #12
m.flores.0928
Drives: 2014 Yaris
Here's some more pics of how it bolts up for those who may not have seen it before
Old 03-11-2018, 06:12 PM   #13
justanotherdrunk
Drives: 2016 SE
nice
does it hang down low enough to be seen from the rear?
Old 03-11-2018, 06:15 PM   #14
m.flores.0928
Drives: 2014 Yaris
Originally Posted by justanotherdrunk View Post
nice
Not even close hahaha
Old 03-13-2018, 07:38 AM   #15
IllusionX
Drives: 07 Yaris Sedan Aero
nice
You don't see it at all. And barely even see it through the wheels.
Sent from my SM-G930W8 using Tapatalk
Old 03-13-2018, 07:40 AM   #16
IllusionX
Wow I miss having a clean sway bar like this lol
Road debris hit the exposed portion of the bar. Not sure how mine looks now, but the bolted part has started rusting years ago, so did the sharp edges.
Old 03-11-2018, 06:51 PM   #17
06YarisRS
Looks amazing! I want one. Alas, I will have to wait as I just dropped a bunch of $$ on the new audio system for the 06.
Old 03-12-2018, 03:14 PM   #18
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I've gone back and forth on this mod. Those that put their Yaris' to the test in real deal race environments claim that a good set of coilovers is all you need with this car. Those that drive on the street say it makes a yuge improvement. I tend to lean towards the guys who are beating these cars up on the track but I recognize that they're two different environments, so results may vary.
On Instagram
On Wheelwell
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
2005 echo sway replacement sway bar meemadd Performance Modifications 7 08-15-2016 11:56 PM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
