Old 07-30-2009, 11:01 PM   #1
JOHNTIFF11
Drives: YARIS
How to diy ac belt
My belt is screaming when ac is turned on. I was told it needs to be replaced but not going to pay 120 dollars when i bought the belt for 15. Just need some guide on how to replace it. pics would be a big help also. Thanks for time and any help you can give.
JOHNTIFF11 is offline   Reply With Quote
Old 07-31-2009, 05:48 PM   #2
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Do you need any special tools? IE: belt tension gauge or something? I know there must be some specification to how tight it must be.
devinlamothe is offline   Reply With Quote
Old 07-31-2009, 09:50 PM   #3
Morgan
Morgan's Avatar
Drives: 07 MM LB
no should just be loosen that bolt (pointed to with red arrow in pic above) and get something like a crow bar/handle to the floor jack and leverage it against the engine and push the alternator out/towards the bumper to increase tension OR you can hit the top of the alternator with a hammer til its in the right place... sometimes these things A LOT of force, can't really hurt it by whacking it
Old 08-01-2009, 12:36 AM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
maybe use a rubber hammer or dead blow mallet as the alt housing is aluminum? hehe
Old 08-10-2009, 11:47 AM   #5
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Sorry, this is terrible advice. You most certainly CAN hurt an alternator by hammering it. Someone elsewhere said a replacement alternator cost them $700+!
As pointed out elsewhere, you have to loosen the base bolt(s) as well as the adjusting bolt on top - the alternator can easily be moved by hand then. Tighten to specs, then tighten the top bolt, then the base bolt(s).
Sir A.Y. Atoyot is offline   Reply With Quote
Old 08-11-2009, 09:35 AM   #6
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Yep........agreed and thanks Scott for the schematic. That's some of the most idiotic advice I have heard.....you can't hurt and alternator by hammering it?????? -- Sweet Jesus. Please stop working on your own car.
DerFlosser is offline   Reply With Quote
Old 08-01-2009, 11:42 AM   #7
Morgan
Morgan's Avatar
Drives: 07 MM LB
Sure! To get mine to move I also loosened the bolt underneath the alternator and sprayed everything with pb blaster
Old 08-06-2009, 10:38 PM   #8
JOHNTIFF11
Drives: YARIS
I loosened that bolt in the pic above and tried moving it and it wouldnt budge. The other bolt you referred to as loosing also where would that be located, there are several bolts that i can see looking down? Did you use something to move that might work better than the backside of a hammer? THanks for all the replies above. Just need a little more help to get this completed.
Old 08-06-2009, 11:01 PM   #9
The second bolt is on the bottom of the alternator. Loosen it and the one above and you can easily pivot the alternator (on the bottom bolt). No need for whacking. After you get the new belt on, just use a bar or hammer handle to hold tension on the belt, while you tighten the top bolt, then tighten the bottom.
The belt deflection spec is 7 to 8.5 mm for a new belt and 11 to 13, once the belt has been run.
Old 08-09-2009, 10:23 PM   #10
Marthos
Marthos's Avatar
Drives: 07 3Dr LB
You just bought this belt, it sounds to me like you just need it tightened up some.
Is this the same place that sold ya the new belt???
Go to different shop and ask them to tighten the belt, DO NOT ask them to check the belt, if you need a new belt they will say so, if you dont they will tighten yours.
If you go in a shop and ask them to check the belt, they are going to sell you a belt.
These belts should be good for a long time, if it has been slipping a long time it might be bad.
Bad belts have cracks and/or missing pieces and/or lots of glazing (belt is shiny).
Marthos is offline   Reply With Quote
Old 08-09-2009, 10:27 PM   #11
Marthos
Marthos's Avatar
Drives: 07 3Dr LB
NM miss read the OP.
Old 08-11-2009, 12:25 PM   #12
Shroomster
Shroomster's Avatar
THE LAST TWO POSTS (AND THIS ONE) NEED TO BE DELETED BEFORE THIS THREAD GETS TURNED INTO A FLAME WAR. I don't think they add anything to the topic at hand, just negativity.
I already stated that it would be wise to use a rubber mallet (if the alt) is stubborn.
PLUS Morgan did a retrofit charger on her car so please do not attack her mechanical prowess.
Old 08-11-2009, 01:43 PM   #13
1stToyota
1stToyota's Avatar
They don't need to be deleted. Whacking an aluminum housing with a hammer, stating that it can't be hurt is just wrong. If you want to see negativity and flamming, wait for someone to come to this thread with an alternator with a cracked housing because they followed bad advice..
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-12-2009, 12:14 AM   #14
Sir A.Y. Atoyot
Drives: '08 5-door
Why do you want to delete my post? I just said that hammering on an alternator was a very bad idea, potentially disastrous financially. I said it politely, not in a flameworthy manner. If terrible advice is left unchallenged, some inexperienced people might take it seriously.
Here's another bit of free advice (I spent years working as an auto electric mechanic, so I've tightened a lot of alternators.) When you're prying on an alternator to adjust the belt tension, make sure that your pry bar only contacts the front housing, which is thick and strong enough to take it. Putting a lot of force on a rear housing can very easily crack it, or even shatter it.
Old 08-11-2009, 01:23 PM   #15
devinlamothe
How can you gauge the belt deflection spec? Is there a tool?
Old 08-11-2009, 01:36 PM   #16
There are tools called belt tension gauges. They are either generic ones that measure torque in ft lbs or in lbs or they are manufacturer specific ones. The mfg specific ones are calibrated for a specific amount of force. You press the spring loaded gauge against the belt and read the scale.
I personally don't own one. For something like the spec above, I press against the center of the belt span with one finger and look for about that much deflection.
Old 08-12-2009, 01:01 PM   #17
devinlamothe
Sweet thanks for the info. Further to this, I went to my local PartSource and asked if they had any belt tension gauges, and the guy there looked at me like I was an alien and told me there was no such thing.
I'll try the finger press thing and see.
Old 08-11-2009, 09:06 PM   #18
JOHNTIFF11
Drives: YARIS
I apprecitate the pick CTscott. I got a wrench on it and tried to loosen it and the bolt will not move. I put a lot of force on it with no luck. i sprayed some stuff on it to hopefully free it up at little. Just to ask its not reverse threaded right? I hardly doubt it is but you never know. I just dont want to break the bolt head off. Thanks again for the people that are giving the good advice and help.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
