Old 06-03-2009, 03:19 AM   #1
phenoyz
phenoyz's Avatar
Drives: yaris
spark plugs
when do we change the spark plugs?
anybody knows the oem spark plug model of yaris sedan '08?
thanks
phenoyz is offline   Reply With Quote
Old 06-03-2009, 08:02 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You change them at 100,000 miles.
Old 06-03-2009, 11:13 AM   #3
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
iridium spark plugs?
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Old 06-04-2009, 10:55 AM   #4
Yaris Hilton
Smile
Yep.
Old 06-05-2009, 12:23 AM   #5
_phenoyz_
Drives: yaris
Yep.
do you know the code/name of the spark plug (e.g = bk123456???)
both the sedan and the hatchback have the same spark plugs?
also do they have the same engine as well? (hatch and sedan)
_phenoyz_ is offline   Reply With Quote
Old 06-04-2009, 10:57 AM   #6
hatchbackkid82
Drives: .
the set goes for about $25-$35 depending where you get them from
Old 06-04-2009, 09:05 PM   #7
xairmech
Drives: 2008 Yaris Hatchback
Heard that it may be wise to pull plugs @ say 50,000 miles regap & clean the threads add antisieze to threads & reinstall them if you dont want to buy new ones. This is to prevent plugs from siezing in the heads when you pull them @ 100,000 miles.
xairmech is offline   Reply With Quote
Old 06-04-2009, 11:21 PM   #8
Yaris Hilton
Smile
They're installed with proper antiseize compound at the factory, and gapping's not recommended with the iridium plugs. It is highly advisable to let the engine cool completely before removing plugs from an aluminum head, and to use a torque wrench when installing the new ones, though these are plugs that use a gasket and thus have some leeway on installation torque. If you ever strip the plug hole threads in the head, though, you'll wish you hadn't.
Old 05-22-2014, 07:37 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
i guess u have never worked flat rate...lol that is good idea if u do it urself but honestly not many shops will ...hot or cold they come out lol
Torque is ...snug plus one lol
Old 06-25-2009, 11:56 AM   #10
RedRide
RedRide's Avatar
Yes, this his what many recomend.
Personally, I simply changed the iridium plugs on my othe car at about 60k. IMO, if you are going through the trouble of pulling them, you might as well replace them.
Old 06-25-2009, 03:06 PM   #11
Yaris Hilton
Smile
I'm not going to trouble myself to look at them earlier than recommended, as long as it's running OK.
Old 06-05-2009, 12:35 AM   #12
supmet
Drives: 2007 4 Door Yaris
^^the sedan and hatchback have the same engine and spark plugs
Any dealer or parts store will be able to get you the right iridium spark plugs
Old 06-05-2009, 08:43 PM   #13
Yaris Hilton
Smile
Google "Yaris spark plugs" and you'll quickly find the part numbers. Yes, the engine is the same in the U.S. sedan and liftback models. 1496cc 1NZ-FE.
Old 06-25-2009, 11:46 AM   #14
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I had no problems pulling plugs at 80,000 from factory. I did mine a little earlier then 100,000 a my own personal insurance, they looked very good. I will probably change mine again at 150,000.
198K Miles
N9QGS is offline   Reply With Quote
Old 06-25-2009, 06:02 PM   #15
SilverGlow
Drives: 2007 Yaris Hatchback
Insurance against what?
What?
Nothing!
Changing them out before 100,000 miles is a waste of time and money.
SilverGlow is offline   Reply With Quote
Old 06-26-2009, 04:00 AM   #16
Yaris Hilton
Smile
Yep. If you leave plugs in place way past the recommended change interval till they're totally shot, what will eventually happen is that a Check Engine Light will come on with a code for random misfiring. No BFD.
Old 05-07-2014, 11:43 PM   #17
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Or even worse. I can remember when I was in college and working closing shift at Subway. Closed up the restaurant at 0200 and my coworker headed out while I took care of the alarm and cashout. This was back in 1995 when cell phones for all intensive purposes were still bag phones and expensive. I come out to my parent's 86 Corolla with close to 200k miles on it and turn the key...................fires then, POOF! Long story short, original spark plugs and one of them had the porcelain disintegrate. Tried to to call the 'rents on the house phone, but of course they slept through it. I walked the 14 miles home.
sent from my m-o-b-i-l-e
Old 05-07-2014, 10:13 PM   #18
Scipher
Drives: 2008 Toyota Yaris
I just wanted to come on here and say thanks to you guys for giving me the proper advice to get the job done properly. I'm so impressed I made an account and plan on contributing what little knowledge I have to the cause. This website is awesome.
Scipher is offline   Reply With Quote
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 09:38 PM
