Old 09-20-2006, 08:30 PM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Disable your seat belt alarm (on/off switch)*
What for:
If you want to disable your seatbelt alarm. I tend to do alot of work on/in my car and I hate the alarm when I turn the car on. So I wanted away to temp disable the alarm.
Tools Needed:
- Wire strippers/wire cutters
- Drill bit (1/4inch)
- Drill
- Elec. tape (or shrink wrap)
- 10mm socket (for removing center console)
You need to buy/have:
- switch (on/off) ($1 - $15 depends on your taste, mine was $3)
- 2.2k ohm resisters ( $0.99 radioshack) (thanks -*03Z33)
How you do it:
1. I removed the center console (check the service manual)
2. On the center side of your seat there is a small rubber "hose" with the seat-belt wire
3. Cut away some of the rubber hose, and expose the wire's
4. Seperate the wire into "2" then strip a bit of each (you could prob remove the seat and then tap into the wire alot easier... but taking the seat out sounds like a bitch)
5. Use a piece of wire (about 7inches) and attach the wire's together
6. I put a 2.2k ohm resister "in-line" on one side of the wire
7. Hook up the wire to a switch (i used a push-pull on off switch)
8. Tape all your splices (I would recommend you to use heat shrink)
9. Test, TEst, Test
10. I chose a location on my center console that was accessable but hidden (under my e-brake handle)
11. Drill hole, put switch in hole/place
12 . Put everything back together
13. Enjoy your new found ability of control over that 12sec chime....
will work for parts
vodkalush is offline   Reply With Quote
Old 09-21-2006, 08:04 AM   #2
bzk
Drives: Yaris sedan
i read somewhere in the manual that the dealer can disable this.....
bzk is offline   Reply With Quote
Old 09-21-2006, 09:03 AM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
yah but theres no fun in that...
and I didnt really want to disable it; just temp. when I'm driving down to the garbage "dump" (its on the other end of my townhouse "block") and what not.
will work for parts
Old 09-21-2006, 09:01 AM   #4
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Is it necessary to put a switch or just cutting the seatbelt sensor wire may be enought to disable it forever? It is a very annoying feature of the new Toyota (my mom also have it on her new Matrix), so I don't think people will want to re-enable it further... hehehe.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-21-2006, 10:32 AM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
What is the point of the resistor?
because you are adding a length of wire?
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 09-21-2006, 01:23 PM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
my guess is that there is a resistor in the acutal buckel reciever... or somthing along that line, because when i simply "shorted" the factory wiring the alarm would not go off.
will work for parts
Old 09-21-2006, 01:13 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
nice DIY...that is what I would be looking for as well....just a temp solution when I am detailing or have my laptop backpack on the passenger's seat....I would like to be able to still have it on because I prefer to wear my belt, but would forget all the time without the chime.
Old 09-23-2006, 06:32 PM   #8
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
what wire did you put the resistor on or will any wire work
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-23-2006, 06:32 PM   #9
KSIbucky
KSIbucky's Avatar
where do you buy heat shrink
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-23-2006, 07:21 PM   #10
KSIbucky
KSIbucky's Avatar
did you sodder the switch
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-23-2006, 07:50 PM   #11
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
i'm just wondering... can't you just get a used seatbelt buckle latch from the junkshop and plug it in your setbelt buckle to stop the chime?
jeff_o is offline   Reply With Quote
Old 09-23-2006, 08:47 PM   #12
vodkalush
I drive a yarrrris
vodkalush's Avatar
Any wire will do
I used elect. tape but you can find heatshrink at either lowes/rad shack should have it as well
No the switch I used had "Screws brackets", if you look at the switch picture you can see the 2 wire "inputs".
you could do that, but I did this for a temp solution, not for a full time. So if your looking for a full time solution then that would prob be the easiest way.
will work for parts
Old 09-26-2006, 08:29 PM   #13
KSIbucky
KSIbucky's Avatar
how did you make the hole for your switch (what tool?)
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-26-2006, 09:18 PM   #14
vodkalush
I drive a yarrrris
vodkalush's Avatar
a cordless drill and a wood/metal bit (I just used what i had)... the hole size depends on what button you use/get.
will work for parts
Old 09-27-2006, 01:37 PM   #15
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
I just went to five different dealers, and no one will disable the dam alarm. They don't care what it says in the manuel they just won't do it. Liability issues they tell me. Any other way other then adding this switch? I'd just like to get rid of the alarm completely. Maybe a certain wire being cut?
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 09-27-2006, 02:58 PM   #16
vodkalush
I drive a yarrrris
vodkalush's Avatar
if you want to disable the alarm completely just cut the wires (as in pic) and connect the two with a resistor. (image below) I would use heatshrink around the connection points (at min. electrical tape)
will work for parts
Old 11-11-2006, 01:24 AM   #17
grimez
grimez's Avatar
Drives: 2007 Yaris
So theres no simple way of disabling the sound alarm (ie not cutting wires)? This seems like a huge pain in the ass for something so simple.
grimez is offline   Reply With Quote
Old 11-11-2006, 02:01 AM   #18
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
there is. Find a dealer that will do it. or me I just went to the dealer I used to work at and had one of my service guys do it for me with no one knowing.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
