Old 04-09-2015, 07:30 PM   #1
chief ten bears
chief ten bears's Avatar
Valvoline Maxlife ATF
anyone using or have any experience with this? The bottle says compatible with Toyota ATF WS. I'm thinking of using it in my 2007 Yaris.
thanks!
chief ten bears is offline   Reply With Quote
Old 04-10-2015, 10:50 AM   #2
woops
Drives: Jeep Cherokee XJ 1996
Valvoline ATFs are good but, nothing beats the ATF WS by Toyota - I'd use the valvoline only incase I'm unable to find the Toyota ATF WS
woops is offline   Reply With Quote
Old 04-10-2015, 01:29 PM   #3
clarenceie
Drives: Yaris Sedan
I used this ATF. I bought my 2007 Yaris with 80k mi when I swapped the OEM ATF-WS with this Valvoline Maxlife. I tried to not mix them together, to do that, I did the following...
I dropped the trans-pan, changed the filter, unhooked one of the cooler lines and ran the engine to flush out the remaining fluid while putting in the new Valvoline.
Works just fine. The car is driven 100mi a day in 60% city and 40% highway. It's been there for 2 years and changed every 50k miles. It was better than the fluid it replaced.
clarenceie is offline   Reply With Quote
Old 04-10-2015, 11:32 PM   #4
chief ten bears
Thanks. I ended up getting WS from a local dealer. WS was $7 a litre and Maxlife ATF was just over $6. Also picked up two 4 litre jugs of Super Longlife Coolant for $17 each.
Sent from my Asus MeMO Pad using Tapatalk
FYI VOA: Toyota ATF Type-WS craigq DIY / Maintenance / Service 10 06-24-2014 11:53 AM
Replaced my ATF markitect DIY / Maintenance / Service 6 01-02-2014 11:10 PM
ATF Drain and Fill DMZ DIY / Maintenance / Service 7 05-31-2013 12:01 AM
Valvoline 300,000 Mile Engine Guarantee PolarWhite DIY / Maintenance / Service 30 06-24-2009 09:51 AM
