#73 |
![]() ![]() Drives: 2007 4dr Sedan Silver Streak Join Date: May 2010
I had read that a few times. It works fine with the orange or pink wires but as a + pulse. Now we need to figure out how to bi-pass the remote lock-out once the engine is started.
#74 |
You might want to try disconnecting the white wire to the keyless entry receiver as I mentioned on the third page. He tried the red, but never responded about trying the white.
#75 |
Drives: 2007 Yaris Sedan Join Date: Nov 2010
Is it easy to install a Avital 4111L remote start to a 2007 with no alarm system, no power windows or doors? What would be a fair price for install? I'm a lady with no knowledge on this subject. TIA
#76 |
I am not sure what an installer would charge, but for this installation on a Yaris, it should be at the bottom end of their installation fees, as it is a very easy install. Since your car is an 07, no transponder key bypass is necessary, so only the remote starter is required.
#77 |
The disconnecting the white wire to the receiver does absolutely nothing. The keyless entry works in the exact same manner as if it was connected.
Looking through the various diagrams and manuals it looks to me like the CAN bus thing is involved. |
#78 |
It's definitely not CAN between the Main Body ECU and the Door Control Receiver. I believe it's LIN bus, which is much easier to intercept. I need to get my hands on a door control receiver to sniff that data stream.
#79 |
![]() ![]() Drives: scion xb Join Date: May 2010
hey ctscott.. thanks for the pdf file on the diy.. i have a question.. is there a door trigger on a 2008 yaris h/b with no power windows/locks? lmk thanks
#80 | |
FL-red wire 4A-21, FR-light blue wire 4A-24, RL-green wire 4A-5, RR-light blue wire 4A-20, Trunk/Hatch- Sky blue wire 4A-7 If the alarm only has one input for the 2 or 4 doors, you can tap all wires together. |
#81 |
is there suppose to be any wire on the pin? cause there is none on the wire you mentioned? or just stick the wire from the alarm in the open harness that you mentioned?
#82 |
#83 |
yup no wires
#84 |
Here's a picture from Crashy, who is an 08 Liftback without power:
Door Inputs - Conn 4A - 08 LB no power copy.jpg |
#85 | |
The 3A diodes should be more than sufficient, as the ignition switch only switches power to a relay coil (~75mA) for starting. |
#86 |
![]() Drives: 2008 yaris Join Date: Dec 2010
2008 yaris remote start issue
i have a 08 yaris and im tryin to hook up a prostart remote starter, the car does have the key immobilezer and i have connected a idatalink by bass module , everything works fine except the car wont start with the remote, it will crank but not start?, i followed scotts diy which is awsome , on thing is that his diy shows a key sense wire where as my starter or immobileizer by pass ask for no such wire. ? woundering if some could please drop some input hear, i am an automoitve tech. and have connected everything as my instuctions say , ANYONE? LOL
#87 | |
Which idatalink did you buy? Can you post a pic of the wiring diagram that came with it? Also, the bypass modules typically have a learning mode, where they read your key, so they can emulate it. Did you go through that procedure?
#88 |
ill try to upload the diagram tomorrow as it is midnight hear rite now , and yes i have learned the key, it wouldnt work at alll until the key was learned. almost seems like its missing a signal form the ign or immizer.
#89 |
What's the model number of the one you bought? It looks like their install manuals are available on their website.
#90 |
this is the by pass im useing and im using type 1 wire diagram.
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 02:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 02:26 AM |
