Old 08-23-2007, 09:48 AM   #55
michoujordan76
Drives: 2005 Toyota Echo Hatchback
How about for Echo hatch?
Does anybody know if this will work in the Echo Hatch (i.e. the previous generation Yaris)?
Thanks!
michoujordan76 is offline   Reply With Quote
Old 08-23-2007, 01:13 PM   #56
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
This will be in my to buy/ to do list.
I saw one at eBay for $96 + $8 shipping.
NST NonStopTuning Toyota Yaris Short Shift Kit
aca72 is offline   Reply With Quote
Old 03-11-2009, 01:25 AM   #57
gmodder
Riceman43
Drives: 2009 Yaris 3door
this thing doesnt fit on a 2009 3dr LB...It doesnt rest far enough down so you put the cotter pin in...
gmodder is offline   Reply With Quote
Old 03-11-2009, 03:06 AM   #58
texkid
The one with cheese on it
Drives: '10 Corolla S
PM sent. Let me know.
texkid is offline   Reply With Quote
Old 03-11-2009, 12:06 PM   #59
gmodder
Riceman43
Ok guys Upon Cali's request Iam posting what i did to make this work...Sorry my camera is screwed so no pics but dont think they are needed..
Basically from stock there is absolutely no way the device will sit far enough down so the cotter pin can slide in...So i put my toyota cap on and thought for about 2mins' (as long as can without getting a headache)
I pulled out my dremel and put the following bit on it..(I know but it was the only one i had to work with) http://www.dremel.com/en-us/Attachme...l.aspx?pid=562
I basically cut down the bottom side of the blk until i couldnot see any red left..I also had to cut a little off the edges..So now the blk is completely silver on the bottom...I did have to test fit about 4 times until i got it just right..Once i had enough cut down I had to press down on the blk pretty hard and it slid all the way down for the cotter pin to slide..Tested a short drive everything seems fine..took me about 20mins to do this...Maybe NST can look into this and make a ver.2 for us 08-09 owners...
Also 1 thing to point out...I dont think it is the depth of the channel on the blk its the edges that are stopping the thing from resting flat...so someone might try just fileing the edges down instead of the whole bottom side.
Old 03-11-2009, 12:18 PM   #60
Thanks for the write up -- glad you got it to work.
Maybe a thinner version with and without a washer would fit both versions?
Old 03-11-2009, 12:20 PM   #61
gmodder
Riceman43
Washer doesnt come in play until you are putting the Arm back on..That cotter pin has plenty of room to slide in..
Old 04-28-2009, 09:25 AM   #62
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
hi all plp... perhaps I missed something... does this actually work on the new yaris 1.33 (100hp) model 2009??
thank you in advance
kind regards,
davide
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 05-13-2009, 10:49 PM   #63
Dysfunctionallx
Caw?
Dysfunctionallx's Avatar
Drives: 08 Sedan
Send a message via AIM to Dysfunctionallx
I don't like the idea of spending close to $100 on something thats made for my car and having to shave it down to make it fit. But thats just me. I'll buy one if the fitting problems get fixed.
Dysfunctionallx is offline   Reply With Quote
Old 05-31-2009, 12:54 PM   #64
naossoan
Drives: 07 Yaris 3DR
$98 for a little piece of aluminum? wtf?
naossoan is offline   Reply With Quote
Old 05-31-2009, 04:53 PM   #65
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The TRD one costs even more. Try making one yourself.
Old 03-29-2011, 12:00 AM   #66
swidd
Drives: Yaris HB
Where was the install moved to? Looks like I scored one, and will need installation instructions.
swidd is offline   Reply With Quote
Old 03-29-2011, 06:52 AM   #67
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Here you go:
http://www.subcompactculture.com/200...nst-short.html
Old 03-29-2011, 08:20 AM   #68
swidd
Drives: Yaris HB
Links to http://www.subcompactculture.com/NST..._Products.html which ... does not exist.
Found this http://scionlife.com/forums/showthread.php?t=124859 instead -- usable!
Old 04-26-2011, 10:37 AM   #69
swidd
Drives: Yaris HB
After installing and running with it for a while, the gears became a bit stiffer to shit into and out of. Kinda like a "dry hump" to get over/into to get into the gates.
Sprayed down the whole NST and gear linkage and top of gear box with WD-40, and it shifts smooth as baby oil.
Are there any ill effects from just whimsically spraying WD-40 around at all places in the car? Avoiding surfaces that get hot, like the exhaust and engine block, can I safely spray WD-40 on everything else without messing up? (nuts and bolts, to keep from rusting)
Old 06-23-2011, 02:22 PM   #70
limey163
limey163's Avatar
Drives: 2010 Black 2D Hatch Yaris
it says he DIY has been moved, but where did that sucker move to?
limey163 is offline   Reply With Quote
Old 06-24-2011, 03:31 PM   #71
swidd
Drives: Yaris HB
limey163, see my post 2 before yours, there's a better guide somewhere else.
Old 06-24-2011, 03:37 PM   #72
Chino jumped ship in a snit in 2009. Removed everything he ever created, leaving us with several useless threads. But, as has been mentioned, post#71 contains a new link.
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
Paddle Shift Kit drell42 Performance Modifications 17 04-14-2007 03:44 PM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 10:15 PM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
