Old 11-11-2013, 11:57 PM   #1
ivanstepul
Drives: 08 hatchback
Looking for tires: What size is the best on 17 inch rims?
I have 17x7 inch wheels. which size is the most comfortable and sporty at the same time right now I'm riding 205/45/17. should I stick with that or go with 215/45/17 or 225/45/17 or 215/50/17 or 225/50/17????????? when I turn the steering wheel all the way I rub with the 205/45/17 will the other large sizes be considerably worse????
ivanstepul is offline   Reply With Quote
Old 11-12-2013, 07:39 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Any of those other sizes will just make it worse. You'd need to go smaller like 205/40
Old 11-12-2013, 12:03 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup...I had 205/40/17s on my DxR 7" wheels and the car LOVED them. NEVER rubbed ever.
Old 11-13-2013, 02:56 AM   #4
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
The closest size to OEM spec is the 205/40/17. 100% no rub and look much more sportier due to lower profile. ;)
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 11-13-2013, 11:20 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
If you're not lowered, 205/40/17's look very, very tiny. Stick with OEM size 205/45/17 with stock suspension. As long as you're running proper offset, the lock-to-lock rubbing is not serious.
Old 11-13-2013, 06:22 PM   #6
ivanstepul
Im lowered 2 inches and the ride is too stiff. if I get larger sidewall tires will that help maybe like a 205/50/17
Old 11-13-2013, 10:12 PM   #7
kimona
kimona's Avatar
If you're lowered 2 inches, then 205/40's are probably the best fit... and a ride that's "too stiff" is the tradeoff.
Old 11-14-2013, 02:14 AM   #8
evo165
evo165's Avatar
Lowered by 2inch... You'll get slight rub with 205/45/17. if you insist for 205/50/17, you gonna tear off your fender inner shield when you rub harder.
If your problem is really being too stiff, my advise is to revert back to stock springs and go OEM 205/45/17. If you wanna to have BEST of comfort and some look to remove the tires gap, go for 205/50/17.
16 inch or 17 inch rims? helladopebev Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 11-19-2013 01:56 AM
Looking for 15 inch stock steel rims hop Canada 2 01-21-2010 07:18 AM
