Old 04-03-2016, 03:44 AM   #1
Nahid
Drives: Toyota Vitz
Should I follow recommended tyre pressure?
My car is Toyota Vitz (Yaris for Japanese market). It has stock tyres which is 165/70R14 81S. The recommend tyre pressure according to door sticker is Front: 250 Rear: 240. As our local tyre shops inflate tyre at PSI gauge so I collected user manual of this car and found that the recommendation in PSI is Front: 36 Rear: 35. But when I went to the local tyre shop to inflate the tyres and asked to inflate as per car recommendation the attendant said higher PSI in front tyres will make the car jump. So he inflated Front: 32 Rear: 35.
Same goes to the spare tyre. Its size is T125/70D16 95M and recommended is 60 PSI but the attendant put 40 PSI.
So should I hear that local tyre shop or do as recommendation?
*a supplementary question: My main tyres size is R14 but spare tyre is D16. This spare tyre was not included with the car, it was kind of a gift from the seller. On the manual I saw that the spare tyre size for this car is D15. So should I change the spare immediately?
Nahid is offline   Reply With Quote
Old 04-03-2016, 09:18 AM   #2
bronsin
bronsin's Avatar
I would keep the pressure according to Toyota.
No understanding of the spare tire problem...
Old 04-03-2016, 05:44 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
On these cars, that factory recommendation is about right for most people's driving to get the best tire wear. You won't see any "jumping" from running those pressures.
Spare tire should be set to it's maximum pressure. Spare tire outside diameter should be the same as the tires you have on the car now. That's all that matters.
Old 04-03-2016, 11:59 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
A space saver spare is sometimes smaller than stock. They should also never be put on the front.
Old 05-21-2016, 10:36 AM   #5
bronsin
bronsin's Avatar
Will it destroy the differential?
Old 05-23-2016, 05:21 AM   #6
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
No, it's more of a safety issue. The walls on spare tires are really thin. If you are ever in a position to make quick turns to dodge something, the spare tire is likely to pull off the rim or will just blow. Also, you want most of your car control in the steering. Having that flimsy tire up front is just not a good idea.
also, you will notice the tread patter on the spare tire doesnt have much on the shoulder of the tire. Not good for turning. Spare tire will last longer if you just put it in the rear.
-Derrick-
Old 05-23-2016, 08:51 AM   #7
Bluevitz-rs
OMG the tire will never pull off the rim or blow up from a quick turn. The only reason you want it on the rear is because of reduced traction for steering and braking. It wouldn't pass DOT safety as a passenger tire if it blew up because you turned too quick.
There's a vid on utube of Chris Harris drifting a AMG Mercedes with 4 of them on.
Old 05-21-2016, 06:20 AM   #8
rabbito
rabbito's Avatar
dude its a front wheel drive...front wheel tire pressure should be higher 😂😂😂😂
Cosmetic: Toyota red emblem
Old 05-24-2016, 05:11 AM   #9
ilikerice
ilikerice's Avatar
LOL, calm it down. You got to put the fear of god in people for them to listen
-Derrick-
Old 05-24-2016, 05:13 AM   #10
rabbito
rabbito's Avatar
we got Gran Turismo player in this forum..lol 😂😂😂😂
Questioning the Recommended Tyre Widths based on Offset Energiser Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-24-2012 11:32 AM
What tyre pressure? whoguy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-29-2011 10:00 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 05:46 PM
