Old 08-09-2007, 04:41 PM   #127
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Originally Posted by Doc Zaius View Post
So how do these things look like with the turn signal on? B/C they're half-covering the turnsignal reflectors, right? Any pics would be appreciated...!
No effect Doc. The entire top of the headlamp unit contains the bulb. You also have the side marker lamps for turn signals (and in my case the nifty LED mirror signals)....
redyaris is offline
Old 08-09-2007, 05:20 PM   #128
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
What I meant was (refer to pic attached below -- thanks Thomas) was that the turn signal shines through 2 clear windows, and has this opaque, frosted bit in the middle. The clear window closer to the center of the car is now mostly covered up (I'm going from memory here... at work right now). So I'm wondering if it looks weird having the turn signal flashing out of this little corner under the eyelid.
Thoughts?
2006 Red Blitzed RS 5-door
Doc Zaius is offline
Old 08-09-2007, 10:10 PM   #129
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
good question.. I also wonder if there is some weird legal issue here too since its covering it partly.... not that I care.
AlphaFox is offline
Old 08-09-2007, 11:58 PM   #130
paradigm
o.O
paradigm's Avatar
Drives: 8
Mine are very very slighty a different color but its not that easy for me to notice. Everyone that's seen it so far hasn't really been able to tell.
paradigm is offline
Old 08-10-2007, 12:33 AM   #131
Thoughts?
Well, the signal bulb and reflection in the housing will still be clearly visible from the front and sides, so it will not cause any problems in that respect. Which I think is the real beauty of this little add-on, it's almost as if the car designers wanted people to add eyelids...
eTiMaGo is offline
Old 08-10-2007, 02:11 PM   #132
redyaris
redyaris's Avatar
Thoughts?
Well the bulb itself is sitting on the outboard side of the housing...any reflection that gets 'blocked' will be on the inboard side.
As far as getting pulled over im sure Police from coast to coast are busy adding 'illegal eye thingies' to their lists while bridges are collapsing and mass murder is being committed.
redyaris is offline
Old 08-11-2007, 01:04 AM   #133
DMart
same amount of posts lol
DMart's Avatar
Drives: 07 Meteorite Metallic LB
so i got my eyelids today but it seems as tho they were wrapped up in the bubble wrap while the paint was still wet because it has marks all over it, at first i thought it would come off but its embedded in the paint, did this happen to anyone else? sorry to bring bad news, overall they're great, still a thumbs up
DMart is offline
Old 08-11-2007, 03:37 AM   #134
xCookiE
xCookiE's Avatar
Drives: RED 06
mines are like that too..
so im hoping the car wash tomorrow i go to will take them off.. cuz.. it doesnt look that great.. lol
other than that.. its pimpin
xCookiE is offline
Old 08-11-2007, 06:28 AM   #135
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Wow... that sucks!
I had some eyelids repainted and waited 24 hours for them to cure. Apparently, looks like 24 hours wasn't enough for some of them.
How deep are the bubble marks embedded into the paint? If it's not too bad, a good polish should be able to take care of the problem. If the marks are deeper, however, things may get more complicated to fix. It could be as easy as getting new clearcoat on, or as bad as getting the eyelid repainted.
This is all part of the learning process for me, I guess. I'm going to be waiting for at least 48 hrs from now on before I ship these. Also, I might also change the packaging material, since apparently it's not helping matters much either.
I'm really sorry for these problems, guys. I guess there are 2 ways to get this remedied: Either I reship new eyelids to you, which will take some time (24 hours to get them painted + 48 hours to cure + 24-48 hours to show up at your door), or you can get them repainted at your local body shop. They already have the color they need to get it matched, so it really shouldn't get them long at all to get done.
Of course, price is another issue. I would need you guys to let me know how much they would charge to repaint. I am willing to help out however I can, but I really don't have much money left over, so I would really appreciate some help from your side in order to minimize costs as much as possible.
I am available as always through PM or IM, so please let me know if you have any comments/concerns/suggestions.
Thanks again for your understanding!
tk-421 is offline
Old 08-11-2007, 06:43 AM   #136
tca4
tca4's Avatar
Drives: Yaris RS (white)
Yea i was wonder what made these circlish mark on one of the eyelid.....now i see if the bubble wrap. It is pretty deep, at least deep enough that i can feel the surface is not smooth.
tca4 is offline
Old 08-11-2007, 06:49 AM   #137
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Do you think that only the clearcoat surface has been affected, or the paint as well?
tk-421 is offline
Old 08-11-2007, 11:55 AM   #138
DMart
DMart's Avatar
here's a pic, from my cell, but u can see what i'm talking about
DMart is offline
Old 08-11-2007, 12:03 PM   #139
DMart
DMart's Avatar
Wow... that sucks!
how much do you think they'll charge to get them painted?
DMart is offline
Old 08-11-2007, 06:24 PM   #140
tk-421
tk-421's Avatar
Drives: 5D-07-LB
It shouldn't cost too much for something this small, but I really can't say for sure.
Another idea would be to place the eyelids in an oven for a few minutes. That should loosen up the rough areas and evenly distribute the paint. Of course, this would have to be done at very low temperatures so as to not burn the eyelids up. This may also mean that the double-sided tape on the bottom may become unusable after this procedure.
I've been trying to contact the painter, but he's not available at the moment. My suggestion then would be for you guys to hold off on doing anything to the eyelids until he tells me what should be done to fix them properly.
tk-421 is offline
Old 08-12-2007, 02:34 PM   #141
AlphaFox
AlphaFox's Avatar
OMG.... this really sucks!
Im getting mine tomorrow, I hope they arent that bad.
AlphaFox is offline
Old 08-12-2007, 02:35 PM   #142
AlphaFox
AlphaFox's Avatar
I received the eyelids from tk and have just returned from shipping them out via UPS ground.
PM me for your individual tracking number and expected date of delivery.
I have installed mine. Here are some pics:
how come yours look perfect red? did you have this issue??
AlphaFox is offline
Old 08-12-2007, 04:21 PM   #143
paradigm
o.O
paradigm's Avatar
Drives: 8
Not all of them came out that way. Mine didn't come out with any defects.
paradigm is offline
Old 08-12-2007, 08:22 PM   #144
tca4
tca4's Avatar
haha well you are lucky then
tca4 is offline
MEGAN HEADERS! < group buy price! C2AUTOSPL Sponsors Classifieds Area 20 09-17-2007 01:54 PM
GROUP BUY: JDM Eyelids tk-421 Items for Sale by private party 186 07-23-2007 03:00 PM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
Intake group buy? Lowfront Items for Sale by private party 20 11-17-2006 04:45 PM
