Old 09-16-2007, 11:37 AM   #1
tsportman
tsportman's Avatar
Drives: Yaris 1.8 TS
Dash rattle TSB needed !
I suffer a dash rattle inside the instrument cluster.
This only occurs with a cold interior. (e.g. when i leave in the morning)
After a few km's it's gone.
My local dealer "can't find" a TSB, but i've heard about a padding kit somewhere in one of the posts here.
Can anyone post the TSB or the Toyota-number of that kit ?
Thanks up front !
tsportman is offline   Reply With Quote
Old 09-16-2007, 11:58 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
It would be great if all TSB's were located in a specially dedicated section on our forum.
Do you think it's a good idea?
Can anybody help with this?
Who can make it happen?
Old 09-16-2007, 02:15 PM   #3
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
It happened to me. The dealership threw foam strips behind the gauge cluster bezel.
nick1983 is offline   Reply With Quote
Old 09-16-2007, 05:46 PM   #4
RShatchback
Drives: 07 yaris liftback
mine did for about 1k miles - then it stopped, but now my drivers side mirror is making a buzzing sound at higher rpms - i've just about given up, seems like you'll always be chasing rattles in this car...
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories...
RShatchback is offline   Reply With Quote
Old 09-16-2007, 06:09 PM   #5
sam07yaris
sam07yaris's Avatar
Drives: 07 yaris sedan (silver) STICK
take the dash apart.. its a pull type. no need to worry. some areas you need to pull harder since its clip on.. but in the end get electrical tape and put it on the ends of these prongs right behind the dash cluster.. only the prongs.. they have NO padding whatsoever.. since then no rattle.. it's been a year and no problems :)
sam07yaris is offline   Reply With Quote
Old 09-17-2007, 05:18 PM   #6
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
it could be your air box if you don't have a CAI if you tighten it to much or not enough it rattles squeast
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-17-2007, 05:30 PM   #7
BailOut
Steals terrorist's lunch
BailOut's Avatar
It would be very hard to mistake a dash gauge cluster rattle for an air box rattle. The issue here is the dash gauge cluster.
- Brian
Share the Road
Old 12-09-2008, 08:28 AM   #8
tyler2569
tyler2569's Avatar
Drives: yaris sedan
T-SB-0304-08 is the TSB For dash rattle
tyler2569 is offline   Reply With Quote
Old 12-09-2008, 09:04 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
There's a TSB for early 07 camry's dash rattle. My toyota dealer did that TSB on my yaris.... it went away for couple days, but came back after... then i found out the noise came directly between the cluster and the cluster cover....
Old 12-09-2008, 01:06 PM   #10
gid
welcome to the club . This is what you get with cheap plastics . Done the instrument cluster fix for the '08 sedan . Got to the point where it's best to turn up the stereo or keep window down during warm weather so wind road /noise drowns out the rattles . Seems like the more rattles I repair the more pop up that were in unison with other noises or covered by the louder squeaks / rattles .
Old 12-09-2008, 05:03 PM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
thread is a year old boys.
Old 06-29-2009, 02:12 AM   #12
soup1207
Drives: Yaris 2009 automatic
is it happen when the rpm is low? Mine also has a problem of rattle noice and the dealer said it's from the dash board. However, they reinstall the foam and said it's gone. It actually didn't gone. I just drive it and it happen again. I am gonna take my car to them to have one more time fix....it's the fourth time I am gonna be there for my car...
I want to make sure if my case is really a dash board problem ....
soup1207 is offline   Reply With Quote
Old 07-06-2009, 11:02 AM   #13
cdavidhess
cdavidhess's Avatar
Drives: 2008 White Yaris Sedan 5 speed
I just had my dash rattle fixed today per the above mentioned TSB. My rattle occurred in warm temperatures particularly when I first start out in 1st gear.
The funny thing is that the dealer originally told me that it would take 1 or 2 days to fix the rattle and that I would have to leave the car for that period. It turns out that the repair took 1 hour. The rattle is gone.
cdavidhess is offline   Reply With Quote
Old 07-06-2009, 12:33 PM   #14
PatrickJohnson
Drives: 2008 Yaris LB
that's not really unreasonable. until the TSB was released, they would have to search the car for the source of the issue. once Toyota says "hey, the rattle problem is this and here is how to fix it," they no longer have to go through the problem of diagnosis and can perform the predetermined repair.
PatrickJohnson is offline   Reply With Quote
Old 07-06-2009, 06:20 PM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Compilation of Yaris TSB's: http://www.yarisworld.com/forums/showthread.php?t=9753
Rattle TSB I found the other day. ToyotaTEch21 DIY / Maintenance / Service 37 05-29-2018 11:17 AM
replacing dash whooppee777 In Car Entertainment + Electronics (audio / video / alarm) 8 06-26-2007 03:23 PM
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 02:40 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
dash problems...help needed foggy08 DIY / Maintenance / Service 1 01-25-2007 08:04 PM
