Old 11-06-2008, 12:36 PM   #199
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I hope he does, and I'm the one selling them.
Hey Cali, is he really going to be making more than just the ten? I would love to buy one but my bank account is recovering from getting married. If you are getting some of these what's your time frame after this initial 10 are produced?
Galavoxx is offline   Reply With Quote
Old 11-06-2008, 03:09 PM   #200
I'll talk to him again -- I'm working on having the production run include some extras for me to carry in my store. stay tuned... (so to speak)
Old 11-06-2008, 03:14 PM   #201
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
hold crap ITBs would be so awesome!
Old 11-06-2008, 05:47 PM   #202
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Thanks for the info. I will have one of these!!! ...and hopefully a turbo.
Old 11-06-2008, 06:30 PM   #203
at3GG
at3GG's Avatar
Drives: 07 metmet LB
I really hope he gets a small supply of these so I can save up for one.
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 11-07-2008, 02:12 PM   #204
richardholdener
Drives: 2008 Yaris hatch
I probably shot myself in the foot for offering the mid-range manifold, but the comparison does deserve a little insight. Actually, it is possible to significantly increase the torque production at lower engine speeds using the proper intake design. The problem associated with this is that there is almost always a trade off in power at higher engine speeds. The intake is literally tuned to maximize torque production at a given engine speed. It may be possible to give big gains at 3000 rpm but it may also cost power at 5000-6000 rpm(menaing it may make less power than the stock intake). I doubt this is acceptable. I will run a few more tests on the mid-range version and see if there is a happy medium that is better than my previous results. Also I saw posts on difference between Hp & Tq, but in reality to the are mathematically related and any given torque value will have a corresponding HP value at a given engine speed. Tq is simply work or force and HP is that work or force applied over time. In a drag race scenario (or simple acceleration) the intake that will provide the best acceleration time is the one that offers the most average power over the rpm spread required. In the case of the Yaris, this means WOT at 4000 rpm to 6000+ rpm-except in 1st gear.
Well, if I may share my 2 cents, I've had a lot of time to think about this conundrum...
As much as we want, we cannot expect any sensible improvement of low to mid-range torque with just bolt-on NA mods. You must realize that a 1.5L engine can only do so much. Sure, you could get higher compression pistons, a stroker kit and maybe some new cams, but AFAIK those also really come into their own at high RPMs.
The reason is, sadly, there is no replacement for displacement. You cannot expect the torque of a bigger engine, it's just not gonna happen. You won't see Pee-Wee Herman bench pressing 300lb, you won't see a 1NZ with V8 torque...
So, one must realize this intake manifold is not some magical end-all solution to more power. If the best results are a pretty sizeable increase of torque from 2500RPM onward, then I think it is correct for the manufacturer to maximize on this.
This means that yes, on the street, if you drive in a calm and "normal" manner, you'd never really see an advantage. This intake manifold will really come into its own where it is designed to, at high RPMs, so it will be of most use to those who really race their cars, be it on a track or autocross.
It was said in a previous post, or one that was lost with the hack, but this manifold could be compared to a "bolt-on VTEC", as it gives the engine the ability to keep revving far better than stock. And, as with VTEC, the love-hate relationship is that you have to keep the engine at high RPMs to get good power output from it.
If you really want more low-end torque, the most effective solution is more displacement. This is where forced induction comes in, as it can be considered "virtual displacement" (think about this... normal atmospheric pressure is what, 14psi? a turbo running at 7psi is thus forcing in 50% more of atmospheric pressure, thus giving your engine characteristics of one that is 50% larger, or 2.2L. Of course, this is a very rough generalization, kinda like giving steroids to Pee-Wee!). This is why superchargers excel in this area, they start shoving in more air as soon as the engine is moving, same thing with small, responsive turbos that may not create massive boost, but can start to supply it quite early.
There you have it... If you seriously want more low end torque, go for a small turbo or supercharger. Of course, it's $3000 vs $700, I think that's also an important reason why many are wishing for a "low RPM" version of the intake.
I'm in no way an engine expert, so feel free to pick apart what I've just written
richardholdener is offline   Reply With Quote
Old 11-07-2008, 02:27 PM   #205
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
welcome back
Old 11-07-2008, 06:39 PM   #206
hehe, yeah!
Old 11-07-2008, 06:41 PM   #207
mikenacarato
SIPNDEW
Drives: 15 STI
well if the mid range manifold turns out to not be as great, i would love to get a high range manifold, the problem is i came onto this forum late and was unaware of this buy in and dont have the money immediately to do it. will you be offering this manifold one time only or will you produce more as the demand presses on?
Old 11-07-2008, 09:16 PM   #208
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
HIGH RANGE MANIFOLD FTW! Can't wait!!!! RAAAHH!!
Old 11-08-2008, 03:47 PM   #209
sdyaris
Drives: 2010 Nissan Frontier Pro 4x
Can someone repost the dyno's for the two intakes? I know there was a post on it pre-hack. Would be nice to have some reference again.
sdyaris is offline   Reply With Quote
Old 11-09-2008, 03:14 PM   #210
WolfWings
WolfWings's Avatar
If you'd rather, Richard, I'll pull my list and drop the topic for now. I don't want to turn this into a huge headache for you. If it's getting there, like I said a few times in the mid-range thread I'm okay with the mid-range not happening.
Old 11-09-2008, 03:15 PM   #211
WolfWings
WolfWings's Avatar
Since Richard's going to make newer tests, I think posting the old mid-range graph would just confuse matters.
Old 11-10-2008, 01:40 AM   #212
richardholdener
Now that SEMA nonsense is over, I can get the Yaris and start making the production piece. I will keep you guys posted on the progress. I am starting with the high-horsepower version first and only if demand warrants, possibly follow up with mid-range.
Old 11-10-2008, 02:02 AM   #213
PETERPOOP
PETERPOOP's Avatar
can't wait can't wait
Old 11-10-2008, 02:10 AM   #214
Yoda
Yoda's Avatar
can't wait +10 hp ftw
Old 11-10-2008, 02:13 AM   #215
tk-421
tk-421's Avatar
Drives: 5D-07-LB
can't wait for the graphs to be posted
Old 11-10-2008, 03:03 AM   #216
pinoypizzaboy
Drives: 08 toyota yaris LB
i already sold $700 worth of $5.00 pizza mias. cant wait!!
pinoypizzaboy is offline   Reply With Quote
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
EBay: Yaris Intake Manifold ChinoCharles Performance Modifications 21 10-22-2008 04:35 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
