NF210s owners how much bump stop did you cut?
Thank you.
. CLA 250, 4MATIC |
My NF's came with a diagram explaining how much you should cut. I just followed those directions and it came out great.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
toyota
nf is 1.2-1.5 inch drop supposedly cut should be 1.5 inch but you can get a way with 1 inch
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
So, say if you are using NF's now with stock shocks and you cut the bump stops as directed. Will you need new bump stops if you change the shocks later on? Or do you reuse the cut bump stops?
HISTORY REPEATED 11/04/08
I'm reusing. Or you could go all out and get the kit at FatCatMotorsports http://www.fatcatmotorsports.com/FCMstops_Yaris.htm
Thank you so much for your help, I did!
. CLA 250, 4MATIC |
JDM yO!
Now I'm no expert in the field unlike some of you on here, but I was speaking to a technician @ Whiteline (reputable suspension specialists in Australia), and I was advised that it would be okay to not cut the bump stops with spring drops of about 1.1"-1.5". That is unless you plan to drive your Yaris hard. Normal street driving would be okay without cutting.
(Having said the above, it heavily depends on the quality of the streets you drive around. If your roads are like the surface of the moon then by all means, cut them.) I hope that helps. |
#8 | |
JDM yO!
| Lowered Cars Please Read - Bump Stops!!! | Galavoxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 46 | 11-11-2010 04:49 PM |
| Bump stop length for drop springs. | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 02-17-2010 08:37 AM |
| TRD Sportivo with Tanabe NF210's and cut bump stops? | Jerkratt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 07-16-2007 08:21 AM |
| Bump Stop kits now available.... | Galavoxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 04-25-2007 12:51 AM |
