Old 11-22-2008, 11:24 AM   #37
battleversion -- great links!
Just because it's 0-5v does not mean it's a wideband sensor like the kind that come with gauges. The Yaris sensor is a proprietary, unusual hybrid design. To demonstrate this, you cannot replace it with a 0-5v wideband A/F sensor and have it work. (see bold print below)
The rear sensor is an "normal" O2 sensor.
A WRAF sensor is essentially a smarter oxygen sensor with some additional internal circuitry that allows it to precisely determine the exact air/fuel ratio of the engine. Like an ordinary oxygen sensor, it reacts to changing oxygen levels in the exhaust. But unlike an ordinary oxygen sensor, the output signal from a WRAF sensor does not change abruptly when the air/fuel mixture goes rich or lean.
Old 11-26-2008, 02:07 PM   #38
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
That is describing a wideband sensor.
Old 11-26-2008, 07:02 PM   #39
365Motorwerks
Drives: Small and Black
Can I get a single combo Boost/Vacuum gauge or does it have to be boost only?
Does this mean that the intake manifold pressure will show max vacuum at idle and then swing to low vacuum at WOT (S/C not engaged) to boosted psi if the S/C is spinning?
It's been a while since I thought about how an engine functions.
That's the kind I run, heck I even use the vacuum function the more vacuum you see the better your mileage!
This is the same one but I swapped the face and ring to black..
365Motorwerks is offline   Reply With Quote
Old 11-26-2008, 07:09 PM   #40
right... and then there was the rest of my post (which you quoted). Try plugging in a nice Bosch universal wideband sensor in that first bung and running it to your ECU.
I'm simply saying it's not the same.
Old 11-27-2008, 09:41 AM   #41
largeorangefont
Break'em off some.
I didn't say is was a Bosch wideband sensor. There are no "universal" wideband sensors. Then ones you are thinking of that are most commonly used are actually VW parts.
Hondas used NTK wideband sensors, and then whatever the Yaris has in it. Coud be NTK or Denso.
Old 11-27-2008, 12:28 PM   #42
boost, a/f, egt
Old 12-03-2008, 10:00 PM   #43
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
why everbody gets the added hole for the wideband is so it plugs into the gauge and uses it as a seperate monitoring system while the factory ecu reads off the factory installed unit to apply fuel/air more properly and by the way bosch makes a wideband sensor for a replacement for the yaris
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 12-03-2008, 10:05 PM   #44
battleversiontc
i have tried this with my plx device and it works great i havent gotten any cels yet
Old 12-04-2008, 03:40 PM   #45
at3GG
at3GG's Avatar
Drives: 07 metmet LB
beginner question.....besides "boost" lol what does a boost guage pull its reading from? Some line i would assume but which?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 12-04-2008, 04:38 PM   #46
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
it reads the pressure levels from a vacuum line off of the intake manifold.
Old 12-04-2008, 08:34 PM   #47
at3GG
at3GG's Avatar
is that line there stock or added when a boost guage is added?
Tanabe Df210's
Old 12-04-2008, 08:37 PM   #48
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I'll let you know in a week or so. I just purchased an Autometer vacuum/boost gauge from Garm. I have to see what parts came with the Blitz kit to connect to the new intake manifold. Right now, the hole is pugged with an Allen screw.
Old 03-15-2009, 12:17 AM   #49
LtNoogie
LtNoogie's Avatar
Ok, it's taken over four months since I asked the original question. Here's a video of my vacuum/boost gauge and wideband a/f gauge. Sorry for the shaky picture but my camera mount shakes and I had to zoom to get the gauges to fill the screen. The oil pressure gauge has not been connected to the sender unit yet.
I'll be cross-posting the same video in another thread so you don't want to watch it twice.
http://www.youtube.com/watch?v=05RZSyraA5Y
Old 03-16-2009, 12:01 PM   #50
largeorangefont
Break'em off some.
That thing is lean under boost. You need a tune.
Old 03-16-2009, 12:08 PM   #51
LtNoogie
LtNoogie's Avatar
The provided Blitz fuel controller is a black box and not adjustable. Would my only options be larger injectors? Wouldn't that make me run too rich under NA operation?
Old 03-16-2009, 12:14 PM   #52
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I thought you were going to get TC injectors?
Old 03-16-2009, 12:18 PM   #53
largeorangefont
Break'em off some.
No, don't do that. Getting bigger injectors will probably just make the car slower. See my response in your lean condition thread.
My theory is that the black box retards the timing making the OVERALL tune safe. You would need to datalog to see for sure, or monitor EGT.
If you are going to spend money, spend it on some way to tune the car. I think you could easily pick up 15-20 HP from more agressive timing, and richer AFR under boost.
Again, you don't need bigger injectors.
Old 03-16-2009, 12:34 PM   #54
largeorangefont
Break'em off some.
Word on the street, and what really works are usually 2 different things.
If he can find a piggyback, I will tune it for him.
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
Gauges! Gauges! Gauges! at Blow Out Price. MC-BPT Sponsors Classifieds Area 5 06-07-2007 09:55 PM
