Ideal Spacer Width For the Rear?
My wheels are 15x6.5" ET +38
My tires are 205/50R15 I am sitting on NF210 springs These are the spacers I want to get. They're available from 10mm-25mm through MicroImage. Would 10mm be enough for the rear without rubbing, or should I go for 15mm? TIA
der Zeck
10mm on that low of an offset wheel
10mm
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
depending on your suspension you may rub with the +38mm offset.
a 7" +25mm rear is a pretty good look with some camber and coilovers though. :) I think the 15mm would be too much though. although you should look into hubspacers instead of "wheel" spacers. |
#5 | |
Thanks for your help!
![]() Quote:
The spacers that I linked to are hubcentric BTW.
l33t3st Asshole
hubcentric and hubspacer are two different things.
hubspacer mounts between the hub and the axle spacing the hub 10mm (therefore also the wheel). a wheel spacer (hubcentric or not) will space out the wheel only. how are you doing on space between the tire and the fender at full compression? with our setup at +25mm it's very close to hitting the fender and it does on a rare occasion depending on the severity of the bump. |
#7 | |
Really? Didn't know that...
![]() Quote:
l33t3st Asshole
the key is under compression.
fill up your trunk/backseat with fat friends/family and measure away. :) |
#9 | |
So yeah... I think 10mm is definitely as close as I want to get. 15 mm would end up rubbing for sure. ![]() Thanks again for your help guys! On to find hubspacers...
#10 | |
Thats only a 3mm difference. |
![]() ![]() ![]() Drives: 2010 Mazda3 iTouring Join Date: Jun 2007
I can't find those hubspacers for the life of me, I think Evolved Concepts might have went out of business because their website doesn't work for me anymore. I personally prefer the hub spacers over the H&R spacers, IMO the hub spacers seem a little easier to install since you don't have to deal with longer studs.
#12 | |
l33t3st Asshole
a 48mm might fit but i doubt a 51mm would. even a 45mm to a 48mm. it isn't alot when you're in the appropriate range but once you're on the outside edge or inside edge of the range 3mm can mean the difference between rubbing and fitting perfect. |
Yup... Same here. I tried eBay, but there's either Ichiba or H&R wheel spacers. Nothing comes up for the term "hubspacers".
l33t3st Asshole
contact Tamago he may know how to get you some.
Looks like he has PMs turned off on his account.
Contact yarisworld member, caliyaris.
l33t3st Asshole
it should work after today.
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-06-2008 12:37 AM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-02-2007 12:38 AM |
