Old 01-29-2009, 04:58 PM   #1
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Need some help...
Disconnected the negative battery terminal and removed the alternator to install the NST alt pulley. When I got everything back in order and started up my car, the following don't work: power steering, power windows, power locks, radio, heater and controls, and the airbag light is lit on the dash. Any suggestions? Thanks!
cm07yaris is offline   Reply With Quote
Old 01-29-2009, 05:04 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
check the main fuse box under bonnet next to the battery.
Old 01-29-2009, 05:11 PM   #3
cm07yaris
Any fuse in particular?
Old 01-29-2009, 05:17 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
All the main fuses in the box, they are the square ones with a clear veiwing
window , sounds like you have blown them all.
Old 01-29-2009, 05:18 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
i would also check your alternator connections and make sure they are not touching anything.
Old 01-29-2009, 07:04 PM   #6
cm07yaris
Thanks, I'll check it out tonight after class and report back. Can you find that type of fuse locally?
Old 01-29-2009, 07:07 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
more likely you forgot to hook something back up.... check all your connections and look for a loose ground
Old 01-29-2009, 07:32 PM   #8
cm07yaris
It's only a negative battery terminal, 2 plugs on the alt., and a ground on the alt. Pretty sure they are all connected...I'll double check. I don't know why ALL of those fuses would blow.
Old 01-29-2009, 07:34 PM   #9
Black Yaris
der Zeck
more likely did not reconnect something, than all those fuses blowing at the same time
Old 01-29-2009, 08:26 PM   #10
cm07yaris
Fuses seem to be straight. I unplugged the 2 plugs and ground, then reconnected. Still nothing...anyone else?
Old 01-29-2009, 10:15 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
This exact thing happened to me after the pulley install. There's a harness in that area that I broke and needed to replace.
Old 01-29-2009, 11:11 PM   #12
cm07yaris
What is considered broken? The plastic casing is not cracked or anything. The plug on top or on bottom, or the entire harness?! Thanks TK!
Old 01-30-2009, 12:10 AM   #13
tk-421
tk-421's Avatar
Drives: 5D-07-LB
well in my case it was the female end of the plug... they used some epoxy to hold it together... It worked for a while, but it broke eventually.
Old 01-30-2009, 02:39 AM   #14
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
....remove the negative and then the positive look at the big glob of crap on the positive battery wire.....make sure both the fuses are ok....the one is the alternator fuse won't let the car turn over the other is the starter fuse IIRC.... both are like 50A or something....
Old 01-30-2009, 07:52 AM   #15
cm07yaris
The car turns over, starts, and runs perfectly fine. I just have no power to any accessories.
Old 01-30-2009, 11:18 AM   #16
Shroomster
Shroomster's Avatar
well, it sounds like a grounding issue like Black said.....
Old 01-30-2009, 03:45 PM   #17
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
+1 on that or it is the main power wire to the under bonnet fuse box,
double check your earth contacts in engine bay , and check + as well
see picture off fuses , and don't worry about the wires circled in yellow.
they are the fog light wires.
Old 01-30-2009, 03:49 PM   #18
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
you might also look at the fuses in the car under main main junction
check photo it is under that .
