Old 02-11-2009, 09:02 AM   #37
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Sooooo...... You swapped internals on the throttle bodies?
Im sorry but I dont really like hit and miss answers, I do appreciate info though, dont get me wrong.
Old 02-11-2009, 10:30 AM   #38
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by Yaris T-Sport View Post
So the trick to cure the oscillation is simply not letting the ECU recognized the 1zz TB, therefor the ECU will function normally as it thinks it is still operating the OEM 1nz TB
So basically you fixed the oscillation problem by not doing anything? I don't get it.
So what if you ever need to reset the ECU in the future? How would you fix then oscillation issue then?
Old 02-11-2009, 11:31 AM   #39
i have to admit, when i had the TB on my car, i never had an oscillation problem
i unhooked the negative terminal....removed the stock tb, installed the 1zz TB with the gasket maker, let it sit for 20 or 30min to set up
then i started the car and let the engine idle for about 10-15min then went for a spin...
never had a problem...
Old 02-11-2009, 03:50 PM   #40
ddongbap
A change in airflow is a change in airflow. Theres no way you can really trick different air flow.
Old 02-11-2009, 04:36 PM   #41
yarstar
Drives: 2008 Absolute Red HB
Re-install went well with not vacuum leak this time. I let the gasket maker sit on the new TB overnight and it sealed well. WOW! you can really tell this gives you significant increase in the mid-range and top-end. My car really takes off from about 40mph to 60mph.
New Problem: CEL
I've disconnected the battery for the night so it will reset the ECU. I'll give it another try tomorrow.
Any suggestions would be appreciated.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 02-11-2009, 04:42 PM   #42
yarstar
How do I get rid of the CEL light w/o a scangauge? (I hate that light, BTW)
Old 02-11-2009, 04:43 PM   #43
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by AlexNet0 View Post
I hope so, so what should I do, leave it overnight? should I disconnect the battery overnight?
i left a turbo in my passenger floor for two days and it never started spooling
edit: but i left the battery connected...
Old 02-11-2009, 04:43 PM   #44
yarstar
T-sport, would you explain that about using the OEM TB?
Old 02-11-2009, 04:46 PM   #45
Tamago
Tamago's Avatar
Drives: UZJ100
either unplug the ecu cables or disconnect the battery ground. with the engine off of course.
Old 02-11-2009, 04:52 PM   #46
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Might i also suggest pumping the brake pedal to accelerate situation of removing power from your vehicle. Once brake lights no longer illuminate, voila. You can reconnect the battery terminals again.
anonymous user is offline   Reply With Quote
Old 02-11-2009, 04:53 PM   #47
Tamago
Tamago's Avatar
Drives: UZJ100
why pump it?
Old 02-11-2009, 04:55 PM   #48
Tamago
Tamago's Avatar
Drives: UZJ100
he means, when you re-install your OEM TB your CEL will go away lol.
Old 02-11-2009, 06:03 PM   #49
at3GG
at3GG's Avatar
Drives: 07 metmet LB
will this give a decent upgrade in the power dept? or is it more of a throttle response perk?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 02-11-2009, 08:01 PM   #50
yarstar
T-sport - you're a FREAKING GENIUS. I never would have thought of that.
Thanks!
Old 02-11-2009, 08:47 PM   #51
AlexNet0
AlexNet0's Avatar
did i miss something? how did he cure it?
Old 02-11-2009, 09:08 PM   #52
x2
Old 02-12-2009, 06:56 AM   #53
tk-421
tk-421's Avatar
Drives: 5D-07-LB
x3
so confused at this point...
Old 02-12-2009, 07:15 AM   #54
yarstar
Somehow the post got removed.
T-sport stated that you take your OEM TB, lay it next to the 1zz TB on the engine, unplug the 1zz and then plug the harness into the OEM TB, turn the car to 'on' but don't crank. Leave it for a few minutes, turn car off, re-plug the 1zz TB.
This, he says, will 'trick' the ECU to thinking the OEM have been reinstalled and fix the CEL. I haven't tried this yet, but it does sound smart.
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
