#19 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
FYI, I believe stock offset is +45 (at least on the 15" steel wheels).
For everyday driving, you'd probably be hard pressed to notice the difference between a 195 and 205 tire. If you're concerned about the rubbing, go with the 195.
Subcompact Culture: The Small car blog |
#20 |
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
I myself am running 17x7 42mm wheels with 205/40 tires with no rubbing when I've bottomed out or doing full u-turns. I've read a lot of post here with users claiming to have no rubbing with 42mm offset wheels. Even people running bigger tire sizes then the one you're considering. Some post mention rubbing, but most of them dont have issues from what I've read.
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header Last edited by eii; 02-13-2009 at 07:49 PM. |
#21 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
^ i just dont know what to believe anymore =/
#22 |
The tread on an A048 195 tire puts more rubber to the ground than my BF Goodrich 205's in the same height series. Look at the shape of the sidewall -- definitely differences to be found between brands.
#23 |
besides the 15's i also rub with my 215/35/18's. its not an issue with me cause i chose to live with it but i hear it on harsh bumps and when i cut wheel too hard left or right.....
#24 |
this made me lol because i'm sitting here thinking "why do aftermarket wheels have such HIGH offsets?"
#25 |
The fact is that 205mm tyres, for example, actually differ in width by brand and model; all 205mm tyres are not created equal.
Wheel offsets are not always entirely accurate, as well. Plus, the car itself is built within acceptable design tolerances, so not only does each car differ, but the same car can differ from right side to left side. EDIT: These variables along with the fact that the Yaris is already pretty tight when it comes to proper wheel/tyre fitment... and you've got a rather fussy little car. Last edited by kimona; 02-14-2009 at 11:05 AM. |
#26 |
i think it's just the fussy little owners ;)
#27 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
Am running on 17x7 +40 wheels with 205/40R-17 tires. Car is lowered with Eibach Pro-Kit springs. Also installed a 10mm H&R spacer on the rear wheels. Absolutely no rubbing issues.
You shouldn't have any rubbing issues with 195/50x16 tires on +43 offset;otherwise get the +45 offset if you want to run on 205s to be on the safe side.
Benggolf2 |
#28 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#29 |
^ ha, beat me to it!
#30 |
how am i fussy.. i run many different offsets /wheels/tires and don't throw a fit if i get a little rub once in awhile ;)
#31 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
A048s vs R888s would be a good comparison. RE760Sports vs BFG KDW2s etc. looking into measured section and tread width on a given wheel width tells a lot more then the sidewall #s. a little article on the topic. http://t3hclap.com/archives/43 just to show the differences. And no you can't run that size tire on a yaris. |
#32 | |
Rides canyon walls
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
#33 |
looks like we'll be running rota circuit-10's, 16x7, +et45mm. I really want 205 width tires, because any narrower just looks so narrow! Looks like BBS has some good high offset wheels, but they're so damn expensive. I have some 18x7.5 BBS wheels on my IS300, and they're +50mm offset. Definitely not rubbing with those! I wish they were wider though. I could have easily fit a 8" in the front, and a 9" in the back with that offset. I'm running 225 front and back, but i could have done 235front, 245rear =/
| What are you doing right now? | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 26819 | 12-31-2010 11:48 AM |
| want 2 lower with tein but have tyre rub HELP! | MR. CANTON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-24-2007 05:16 PM |
| Got new wheels, tires, and springs installed. | largeorangefont | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 44 | 09-22-2007 05:21 AM |
| SSR Integrals 16x7 +42 | santosspl | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 31 | 07-24-2007 08:12 AM |
