Old 02-10-2009, 01:49 AM   #37
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
aw tamago, where is your desire to solve things mathematically
turboyaris is offline   Reply With Quote
Old 02-10-2009, 04:54 AM   #38
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
100mph car crash and without a HANS device, the driver will lose his head.. harness bar won't even be an issue at that point..
That's quite conjectural, as an F1 driver (David Purley) back in '77 survived a 180g impact, this is way before HANS were commonplace, or even invented:
He survived an estimated 179.8 G's in 1977 when he decelerated from 173 km/h (108 mph) to 0 in a distance of 66 cm (26 inches)
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 02-10-2009, 05:11 AM   #39
jkuchta
Drives: 2007 Yaris hatch (red)
I think the harness bar will survive anything the rest of the driver's compartment will survive.
Slowing from 108 mph to 0 in 26 inches in a yaris without a full rollcage would be unsurvivable IMHO, no matter what restraint system was used. The front end of the car would intrude into the driver's compartment too far.
jkuchta is offline   Reply With Quote
Old 02-10-2009, 05:40 AM   #40
cleong
cleong's Avatar
I'm not asking for a 100mph crash test, perhaps we're going off on a tangent here.
That being said, I have seen almost 100mph on my local track at the end of a 2200+ ft straight. And no, it didn't take two and a half minutes.
So long as a harness bar is at least as strong as the original seatbelts were I suppose that is good enough. Euro NCAP usually tests at only 40mph, though.
TRD Blue brake pads
DC Sports header
Old 02-10-2009, 09:26 AM   #41
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
i wonder if this will have the same issue the TC and XB had where the pillars the harness bar was attached to started to cave in after some time
Old 02-10-2009, 11:26 AM   #42
turboyaris
by this, do you mean that over time the chassis of the tc and xb began to flex causing the B pillars to come closer together? If that is the case, this bar should help that, as it would continuously be holding it at the dimensions it is installed in, if your car has already had this "dimension change" that is the reason for the slot in the brackets, to allow for slight differences in chassis measurements
Oh and tamago, it looks like the hatchback is 3/4" wider at the B-pillar, or at least thats what the collision section of the factory repair manual says, page DI-5 and DI-8 measurement J-j is the measure from the top of the B-pillars, I will have to double check on a actual liftback.
Old 02-15-2009, 09:40 PM   #43
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Turboyaris, I have a small concern about the design, I will pm you.
rob323 is offline   Reply With Quote
Old 02-15-2009, 10:06 PM   #44
Why not post it so we can all hear your concern?
Old 02-15-2009, 11:04 PM   #45
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
as do i. but no one wants to hear that.. they just want to know what colors they'll be available in.... well.. besides Garm that is..
Originally Posted by xnamerxx
you nailed it sir.
Old 02-15-2009, 11:15 PM   #46
rob323
Nah, my concerns might be totally unfounded in which case it would just be pointless clutter and not beneficial to the thread.
Old 02-15-2009, 11:15 PM   #47
Tamago
Tamago's Avatar
Drives: ZZW30
so only positive comments are beneficial to the thread?
you nailed it sir.
Old 02-15-2009, 11:37 PM   #48
turboyaris
haha I take all concerns, I would like to know yours Tamago,
Robs concern was just in the design and in possibly adding an extra pair of legs, but as I informed him, I didn't believe that it would be a neccessary as I feel the unit would be strong enough to hold up. as many companies have a similar design.
Tamago, was yours just in the design of the upper bracket?
Old 02-15-2009, 11:37 PM   #49
Tamago
Tamago's Avatar
Drives: ZZW30
yes, still concerned with that L bend..
you nailed it sir.
Old 02-18-2009, 06:27 PM   #50
kustom play
Drives: 07 liftback
no i mean people installed a harness bar in there TC and it started to sink the pillar below it
i might be able to dig up pics
dont know about the XB i know thats the reason we opted not to get it for our TC
happened here to somebody local you can see the pillars bent in, it wasnt a good thing
could of been the bar design or something but i know there were a few people who had that happen to them
Old 02-18-2009, 09:16 PM   #51
turboyaris
hmm thats interesting... The only thing i can think of, is that if the bracket and the bar were welded together, as sparco's are, that possibly they were too small, and the customer just wrenched on the bolts and the bar would probably be stronger then the b pillars, he himself might have done it... I don't know, merely speculation
Old 02-18-2009, 09:30 PM   #52
Tamago
Tamago's Avatar
Drives: ZZW30
why not adopt a plate like this... much stronger
you could always shim the bar for the "wider" b pillar configurations
you nailed it sir.
Old 02-18-2009, 10:09 PM   #53
^ very nice --
um... what colors does it come in?
LOL
Old 02-19-2009, 03:02 AM   #54
turboyaris
haha sorry. tamago, I try to make my harness bars look a little nicer... plus the problem with that, or so it appears, is that the bar is higher then the opening in the seat for the harnesses, the bar is supposed to be just slightly lower then those openings... plus, what keeps that bar in place vertically? it looks like that bar could just rotate freely around the seat belt bolt... which could spell disaster.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 05:23 AM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 02:34 AM
Yakima Q towers and roof mounts (no bars, locks) for sale $125 shipped pxpaulx Items for Sale by private party 6 04-24-2007 11:54 AM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 05:19 AM
