Old 02-23-2009, 01:58 PM   #37
markitect
Drives: Yaris
First off awesome writeup!!!!!!!!!!!
I have one question though, for those looking to stay in HS what shocks/struts work well with stock springs? Any side affects with that combination?
Most are designed to be paired with lowering springs so it seems like this would affect their range of motion (I need something that can go over potholes). Of course if anyone knows of reasonably priced adjustable ones let me know.
markitect is offline   Reply With Quote
Old 02-23-2009, 02:45 PM   #38
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i would imagine that the TRD shocks would fair well with stock suspension, since TRD is for their mild 1"ish drop.
R comps will take you a lot further than shocks in HS though IMO
also, keep in mind, if you run a "shorter" shock with stock spring, you'll be compressing the stock spring beyond its original setting, thereby raising your static spring rate :D which isn't bad, but may get you kicked out of HS in a nationals environment. (not that an HS mini is gonna be scared of a yaris.......... )
Originally Posted by xnamerxx
you nailed it sir.
Old 02-23-2009, 03:33 PM   #39
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Hmmm... in SCCA stock class, you can't change the springs or alter the ride height. Dampers are otherwise unlimited... Hmmm...
Seems to me that you could get a generic race shock to replace the rear shocks on the Yaris pretty easily. It's just an eye at the bottom and pin at the top, very common configuration. Get something that you can dial in really some really stiff compression damping for autocrossing and it should do a world of good for reducing understeer.
That, plus maxing out the front camber, and the tires mentioned above... that should do a pretty good job of challenging the competition.
footnote: One of the caveats of the "shocks are free" rule is that you can't alter the spring perch height. Since the spring perches aren't part of the Yaris rear shocks... you should be free to replace those rear shocks with ANYTHING.
Old 02-23-2009, 03:56 PM   #40
Tamago
Tamago's Avatar
Drives: ZZW30
..... and getting the yaris to rotate is by far the most important thing in stock class :D
it's a shame you won't get any real camber out of the front though :(
you nailed it sir.
Old 02-24-2009, 10:27 AM   #41
markitect
Drives: Yaris
I hadn't thought about that, sounds like I have some measuring to do before May.
Old 02-25-2009, 04:42 PM   #42
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
I've looked at the rear shocks and it does seem pretty easy get a shock that fits, Radflo makes a GREAT race shock and they'll make shocks to your dimensions (collapsed and extended lengths) I've ran several sets of their shocks on my previous trucks. The front would be more of a task considering the mount from the strut to the knuckle would have to be figured out. 2.5 inch diameter race shocks on all 4 corners of a Yaris would be fun (well maybe 2.0's would be more reasonable haha)An External reservoir or internal floating piston shock would be nice.
Old 03-03-2009, 01:17 AM   #43
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Very nice infact .
Now I just have to save up to get the same on the fronts
rob323 is offline   Reply With Quote
Old 03-03-2009, 03:53 AM   #44
2006fronty
2006fronty's Avatar
Ohlins right^^^^^^^??? I'm pretty sure that's how they set up their external reservoirs.
Old 03-03-2009, 04:27 AM   #45
rob323
mcasuspension.com
Old 03-03-2009, 05:00 PM   #46
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Question: How would 10mm rear hub spacers affect handling?
Old 03-03-2009, 05:39 PM   #47
kngrsll
Apexing Egg!!
kngrsll's Avatar
i have been meaning to look this up as well.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 03-03-2009, 06:01 PM   #48
Loren
What?
Loren's Avatar
Wider track usually means more grip (for various reasons). So, widening the track in the rear would make the rear stick better. Not really what most of us are fighting for, with a FWD car, you want more grip in the front.
The rear hub spacers are purely a cosmetic mod. (not to be confused with alignment shims)
Old 03-03-2009, 06:21 PM   #49
kngrsll
Apexing Egg!!
kngrsll's Avatar
ah, thats right... i remember a friend of mine use to use them on the front when he would autox (SE-R, fwd).
im still working on this shocks thing, i have to turn in a research proposal this week and its consuming all my time! :(
Old 03-22-2009, 03:27 AM   #50
d1nzfe
Drives: 1NZ-FE
Originally Posted by rob323 View Post
Very nice infact .
whats so different when its invented?
ooops.... just saw the canister! its remoted and camouflaged!
d1nzfe is offline   Reply With Quote
Old 03-22-2009, 03:28 AM   #51
tropicalsuckerpunch
Drives: yaris
Post #1 of this thread doesn't show me yaris handling information?
tropicalsuckerpunch is offline   Reply With Quote
Old 03-22-2009, 03:31 AM   #52
d1nzfe
Drives: 1NZ-FE
canister like this?
AND this?
Old 03-22-2009, 02:49 PM   #53
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
How the fudge did I miss this kick ass thread ?
Old 07-24-2009, 07:53 AM   #54
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Question
the information given in this post is here merely to provide a starting point for your future autocross or road racing endeavors. this is not the end-all-be-all of information on the yaris. as i come across exact situations related directly to the yaris i will add them to this post
uhh... where did the info go?
2007 Yaris Unveiled at 2005 SEMA Show YarisBueller General Yaris / Vitz Discussion 0 01-12-2006 06:28 PM
