Nov 2006
Drives: Vitz S1600 Join Date: Apr 2007
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed Last edited by Yaris T-Sport; 07-13-2009 at 10:47 PM. |
wow excellent idea!
Awesome info! Thanks
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
This bit of info let me dredge up something that might explain why earlier folks had fewer issues with the throttle-body swap.
Some Corolla's came with throttle bodies with ID #22041 on the chip housing. Others have that problematic chip-housing with ID #0D031. What'cha wanna bet the #22041 chip is special in some way? :-)
DUDE YOU ROCK!!!
Thank you for solving this issue for us. I can now finally install mine without a CEL coming on. Does this also solve the high rpm when cold problem? This is great. I am so stoked to get this on the car. It truly makes a difference that can be felt. ![]()
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
Do I need to drill through the bolts in order to crack open the TBs? Is there a better/safer way to accomplish this?
Also, what is the best way to trim the intake tube to fit the new diameter?
I believe they are riveted, so you will most likely have to drill them out. or be really careful prying them out
Edit, nevermind, he beat me to it. |
Cool. I'll take the high rpm at cold idle if we can get rid of the CEL.
Thanks again T-Sport. This made my day.
mind if i make this a pdf for sticky posting if the mods want it?
ok so bigger TB means more air coming in? What is the performance gain with it?
Good? i have stock intake with K&N Drop in filter, do i need to change my intake?
![]() ![]() The difference between fiction and reality? Fiction has to make sense. --Tom Clancy |
SIPNDEW
can anyone confirm after driving over 100 miles that no cel comes on?
BTW this thread is awesome! thanks for doing this! |
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
no CEL over 100 MPH
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Good work on figuring this out. Where did you get a 1zz tb? At a junkyard?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#14 |
#15 |
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
I've had my 1ZZ TB on for over 20K miles and never had a CEL or oscillation of any kind.
You probably got a defective junkyard TB and swapping out that casing fixed whatever problems you were having with it before. |
#16 |
that's another possibility, but it would be interesting if you could look at the model number on yours, to test WolfWings' theory!
#17 | |
#18 |
SIPNDEW
| 1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 07:57 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 08:15 PM |
