Old 03-06-2009, 02:53 AM   #37
Jerkratt
Jerkratt's Avatar
hey blazingbluevitz think i can drop my car off after the kit install and have them take a look at it?
"It hurts more when its wet"
Old 03-06-2009, 10:22 AM   #38
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i use royal purple and have had no issues at all. it shifts better to me.
mikenacarato is offline   Reply With Quote
Old 03-06-2009, 10:30 AM   #39
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
im guessing they'll say your ssk and short shifter is causing problem. but its worth a shot.....
Old 03-06-2009, 10:34 AM   #40
ImportRacer88
ImportRacer88's Avatar
Drives: 4dr Sedan s
Send a message via AIM to ImportRacer88 Send a message via Yahoo to ImportRacer88
Did you get the prob fixed
ImportRacer88 is offline   Reply With Quote
Old 03-06-2009, 11:39 PM   #41
Jerkratt
Jerkratt's Avatar
i dont have my car back yet... still in the body shop...
Old 03-08-2009, 07:33 PM   #42
Pars
Drives: 07 Yaris Liftback
I had the third gear grind. The car had 100,000km on it and I never changed the gear/tranny oil. I got Toyota to flush it and was extremely worried after the flushed since the clutch was slipping when I got it back. But after a several days, the slipping went away along with the third gear grind.
I'd listen to tango and either use redline, or in my case, I'd play it safe and use the Toyota stuff.
Pars is offline   Reply With Quote
Old 03-08-2009, 08:25 PM   #43
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have a 3rd gear grind as well. I feel it at higher RPMs both when upshifting from 2nd and downshifting from 4th. I'm getting it looked at on Tuesday. The mechanic actually drove my car and felt the grind, and he says it's not the clutch, but that it could be somewhere along the transaxle. I also have a new ACT Stage 1 clutch in there, so I agree that it's unlikely to be a clutch problem.
I really hope that the warranty covers it though. They've started to ask questions about my aftermarket parts.
They also changed the tranny oil to OEM about a month ago. Would it make any difference if I switched back to MT90 this early to see if that fixes the grind?
Old 03-08-2009, 08:29 PM   #44
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I get that grind occasionally, however it is only when I shift very hard at high revs from 2nd to third, I have 56k mi. with the engine bay ssk
Old 03-09-2009, 09:55 AM   #45
hatchbackkid82
Drives: .
Just dropped my car off at the shop today in the morning. I'll should know by this afternoon what's going on with my tranny
Old 03-09-2009, 09:55 AM   #46
hatchbackkid82
Drives: .
That's when i get it but i don't have ss
Old 03-09-2009, 09:56 AM   #47
hatchbackkid82
Drives: .
Well i wait for them to give me call back... if they find nothing wrong, then it looks like i'll be ordering a case of redline
Old 03-09-2009, 11:03 AM   #48
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
lol i had the same prob my car has 6k miles on it. Went back to my dealer and they gave me a whole new tranny Even with all the mods i have on. I/H/E and pulley. As long as wat you added on does not directly or indirectly affect the troubled part then you are good. If they deny to fix for free ask them how exactly your mods have contributed to the fail of your trans... you will quickly see how much they can bs and then call them on it. Let them kno you are not stupid and you kno your stuff also.
Yoda is offline   Reply With Quote
Old 03-09-2009, 11:35 AM   #49
hatchbackkid82
Drives: .
When i dropped it off he asked if i had the gear oil changed. i told him that i did it myself a few months ago. He then said well if we find anything wrong with it by default we will let you know. I'm pretty sure they will try and dump this on me. Of course I'm going to raise hell if they do
Old 03-09-2009, 11:40 AM   #50
hatchbackkid82
Drives: .
Ok just got a call back from the dealership... they did here the grind in third gear. They said they wanted to keep the car until tomorrow bc the shop foreman wasn't there. But he said they would give me call tomorrow to let me know what was going with it.
Old 03-09-2009, 11:44 AM   #51
Yoda
Yoda's Avatar
ok cool sounds good
Old 03-09-2009, 12:21 PM   #52
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
you should have just lied about the oil change.. now they are gonna have to see a receipt and the type of oil you put in..otherwise hope you get lucky and get someone who wont care but to give you a better customer service. good luck
Old 03-09-2009, 12:29 PM   #53
hatchbackkid82
Drives: .
I couldn't lie about it... well i could but, they have the transmission drain plug marked with ink. So they know when the drain bolts been removed. I have receipts... put the correct viscosity in there.
Old 03-09-2009, 12:34 PM   #54
marcus
toyota
marcus's Avatar
you got the receipt then they cant decline ur coverage.. ur good to go.
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
Auto 'extra' gear? drecian General Yaris / Vitz Discussion 2 08-25-2007 09:01 AM
High RPM's in 3rd. Need some opinions falkor_99 General Yaris / Vitz Discussion 3 05-16-2007 09:23 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 07:27 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
