Need Wiring Help
I just installed an electric spoiler sunroof - I just need power to it.
I need a circuit to the battery and one that goes on and off with the ignition. I routed the wires down under the driver's side dash. I'd like an OEM installation. How do I hook these into the fuse panel? They should have their own circuit. Thanks. |
Well... I used two of these add-a-fuse suckers and put them in unused spots in the fuse block The only trouble is now I can't put the cover back on. It works for now.
Advice would be appreciated.
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
You're wanting to use the unused OEM panel spots without that adapter thing, correct?
That's what I ended up doing but I'd rather wire directly into those unused panel spots so it all looks factory.
This works but I'm a perfectionist. |
#7 | |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
ummmmm.... I might just have to redo my power outlets so that they all have their own fuse (which is prob the way I should have done it :-) ) on the block.
If I do, I'll make sure to take a ton of pics and post a DIY.
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
![]() Of the Sunroof,That is
Thanks Paul. The fuse block is on the bottom of this:
(image stolen from H8SGAS's thread) Let's just say I was a little intimidated about taking it apart. YamilR - the photos are here: http://www.yarisworld.com/forums/sho...5&postcount=31 |
#11 | |
| US Yaris: Adding a tach? | Thirty-Nine | General Yaris / Vitz Discussion | 159 | 04-05-2007 08:23 AM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
| question about stock stereo wiring? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 07-19-2006 03:22 PM |
