![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2009
I had power locks installed for me by the same company that installed my remote starter, however they did not connect it to the trunk, so if i don't lock it manually, if i close the doors, someone can still get it through the trunk lol! anyway to get that done? did anyone come up with a release switch to open a hatchback trunk?
sorry for misspell on the title, i was in a hurry *trunk* |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
What's a turnk?
I hope my car has a turnk
![]() ![]() ![]() Drives: 2009 Yaris Blazing Blue 3dr Join Date: Dec 2008
My '09 HB with the power package has a powered lock for the hatch that locks and unlocks remotely.
Audio Junky
yeah... a lot of shops will require you to buy an optinal pin sensor to have installed in the hatch area, then the $40 labor to install it.. so a hatch sensor will probably cost you $50 extra... its worth it I think, Also make sure there is a starter kill.
Auto-lock isn't hard. |
i last had my echo hatchback... wires were already ran from the hatch lock to the interior...
it was kinda hard to install aftermarket actuators for the rear lock. so i went and bought the OEM lock motor (100$ at the dealer) |
Audio Junky
good point, OEM motors are the way to go... its possible to do an actuator on a wire cable, but from what i've heard, you probably will end up having to readjust from time to time because of it loosening up.
what is an actuator? is it aftermarket power locks?
Audio Junky
its basically a little piston that can push/pull and object. Generally you have to use two relays with them to make them work... You hit the button and 1 relay engages and you get a push... Hit the button a 2nd time and the other relay engages and you get a pull....and so on.
they are used for all sorts of things, auto locks being the most common, but also on stereo installs for amp racks. |
Thanx for the explanation! I have a remote starter installed, and my power locks are connected with it, i had actuators installed for my doors since they were manual from factory. my question is: How can i program my remote starter to use my aux buttons on my remote for example, turn on or turn off the lights, honk a horn, or even roll down my windows (since i have my kit coming in for the manual to power windows conversion)
| Tags |
| hatchback trunk power |
| Power door lock keyless entry and remote start | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-20-2009 04:14 PM |
| Power Lock button?? | cyberfrogg | DIY / Maintenance / Service | 25 | 03-26-2009 10:16 PM |
| Power hatch lock? | paultyler_82 | DIY / Maintenance / Service | 5 | 09-08-2006 01:15 AM |
| using regular power lock kits with cable style | twixt | DIY / Maintenance / Service | 4 | 08-12-2006 01:18 PM |
