Old 04-22-2009, 07:03 PM   #91
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by t0m4s View Post
did everybody trim the OEM TB gasket to allow more air flow as t-sport did?
I did. That gasket is a joke. I find it hard to believe that it does anything at all.
Old 04-22-2009, 09:40 PM   #92
xbalance
Drives: stock
how to have more air to flow in to a N/A engine?
last time i drove a lancer the swap is easy as the TB is run by a cable but the new Yaris TB is drive by wire, understand to do a swap for TB is not that easy any more...
Is there any TB is direct swap in for Yaris engine?
Do we need to mod the TB plug to fit in the new TB?
Will the ECU have any issue to the new TB?
xbalance is offline   Reply With Quote
Old 04-22-2009, 10:32 PM   #93
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
there are three threads dedicated to this subject. in this subforum.
Old 04-27-2009, 11:31 AM   #94
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
so my CEL came off today as i was driving into work
it kicked back on after about 110 miles of driving, im about 280 now and it kicked back off
this never happened during the first install, so trying it the 2nd way seems to be producing some kind of different result
i'll keep an eye on it and report back any findings
http://www.4055design.com
Old 04-27-2009, 04:08 PM   #95
gwasabi
Drives: 07 Blazing Blue LB
That's because you have air in your radiator hose. What I suggest is take the radiator cap off and run the car in idle until the bubbles don't come up. the fluid should overflow a little and then when it's settled just pop the cap back on.
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 04-27-2009, 04:10 PM   #96
kustom play
Drives: 07 liftback
yea im going to give that a try next
thats the one thing i havent done yet
Old 04-27-2009, 04:13 PM   #97
gwasabi
Also the Random Oscillation is due to the ECU trying to learn what to do with new TB. Did I mention that this method only works for manual cars? anyway, IF you drive around and get random oscillation just start driving a little harder for a while the opscillation should go away. If it doesn't turn the car off then on right away and it should go away. It happened to me for the first few days but after that it was gone. I have the TB on my car right now and I have NO PROBLEM what so ever with the new TB. No cel, No Oscillation. been like that for almost 5 months now
Serious Business...
Old 04-27-2009, 04:14 PM   #98
gwasabi
That ar in the radiator hose part is VERY VERY IMPORTANT! I think i should edit the first post lol
Serious Business...
Old 04-27-2009, 07:24 PM   #99
kustom play
Drives: 07 liftback
it kicked back on again
im going to do it in a little bit and see if it help it at all
Old 05-03-2009, 03:40 PM   #100
kustom play
Drives: 07 liftback
burped the coolant
CEL has went off and it has not come back on again
so i hope this solves it once and for all
Old 05-03-2009, 08:50 PM   #101
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
i hope so too i am still waiting....
Old 05-06-2009, 11:20 AM   #102
kustom play
Drives: 07 liftback
my light went on again
so i give up trying to get it off, im just going to deal with it on
Old 05-06-2009, 05:54 PM   #103
gwasabi
Just keep driving with the lights on eventually it'll go away
Serious Business...
Old 05-07-2009, 12:56 AM   #104
kustom play
Drives: 07 liftback
just turned off again
so hopefully it stays off at this point
Old 05-07-2009, 01:03 AM   #105
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
You are just getting a CEL correct not a CEL + oscillation?
Old 05-07-2009, 01:37 AM   #106
kustom play
Drives: 07 liftback
just the CEL
the oscillation was only about 5 mins after i hooked the battery up and it learned the new air map. I havent had an issue with oscillation since just the CEL coming off and on
Old 05-07-2009, 03:37 AM   #107
gwasabi
Thats probably due to the Coolant just drive around for a bit and let the coolant settle. It'll eventually just go away
Serious Business...
Old 05-07-2009, 11:36 AM   #108
kustom play
Drives: 07 liftback
i burped the coolant, and it went off then came back on now went back off, hasnt come back on yet.
hoping it just stays off, if not then ohh well, i'll just deal
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 11:48 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 03:36 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 08:02 PM
Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 22 01-06-2009 08:34 AM
ambient map lighting? atebit Cosmetic Modifications (Exterior/Interior) 0 11-05-2006 02:15 AM
