#73 |
I thought perhaps there was a vacant ECU connector position that was used by the CAN bus to send juice to the dash light when the cruise was activated.
#74 |
I thought perhaps there was a vacant COMBINATION METER connector position that was used by the CAN bus to send juice to the dash light when the cruise was activated.
#75 |
nickhjort pulled apart his cruise-indicator-free combo meter and I had him check the outputs of the IC that drives the LEDs, before and after activating cruise. The hope was that we'd find an unused output that would be used to drive the cruise LED if present. Unfortunately, no such luck.
#76 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
I'm confused. I've seen someone ask if this can be done on an 08 Yaris LB with no cruise light on the dash, but haven't seen a solid answer. provided I tap the ECM as mentioned earlier, I should be able to do this mod just with no indicator, correct? The ECM cruise programming is there regardless, right?
#77 | |
#78 |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
Subscribed
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
#79 |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
I used to have a Pontiac with cruise control and no indicator lights. In my experience, there's no light actually needed - it's quite obvious whether the cruise is on or off simply from how the car behaves. As for the "Set" light, you'll know immediately if the speed isn't set because the car slows down when you take your foot off the gas.
I'm going to install cruise on my '08 with the proper switch and very tidy wiring when I get around to it. The goal is to make a sufficiently tidy installation that even a Toyota tech will think it's factory, and it will take a lot of looking to prove otherwise. However, I'm not even going to try for indicator lights. It would be nice, but you don't really need them. |
#80 |
OK, almost have the cruise install complete. I have the 08 Yaris LB with no cruise light on the dash. I tapped the ECM a-21 connector @ position 40 and ran the wire to the cruise on/off switch on the dash.
Last question: How do I wire the new clutch switch I just installed? Does the wire from the ecm go to the clutch switch first, and then continue to the cruise on/off switch on the dash? |
#81 |
Where can I obtain one of those clutch switches? As cheap as possible please :)
#82 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
expo2, no you do not put the clutch switch in series with the cruise circuit. In fact you put it in series instead of the jumper wire stated on page 21 of this "DIY" HERE
See my post...#371. Instead of placing the jumper wire in those two slots (as shown in the pics), simply go from one slot to the clutch switch, then back to the other slot. Try to picture your clutch switch in place of my fuse in the pictures. I will be making my own clutch switch tomorrow and I will take plenty of pics. Hope this helps :)
My Car Rules! |
#83 |
Dah, I feel like an idiot and then some. I don't know how I missed your original pics of the clutch switch jumper wires.
Thanks for your help. |
#84 |
No problem. Glad to help :) I will be starting my custom clutch switch here shortly. I have to go find a switch. Then I'll post pictures later this evening.
My Car Rules! |
#86 |
This is the only mod I've ever done that involved the ECM, can someone kindly enlighten me as to it's location? I believe it is in the engine compartment, right?
#87 |
#88 |
#89 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#90 |
Right side of the car as you sit in the driver's seat - the passenger side, in other words.
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
