Old 05-12-2009, 09:46 PM   #73
expo2
Drives: 2008 Yaris HB
I thought perhaps there was a vacant COMBINATION METER connector position that was used by the CAN bus to send juice to the dash light when the cruise was activated.
expo2 is offline   Reply With Quote
Old 05-12-2009, 10:02 PM   #74
nickhjort pulled apart his cruise-indicator-free combo meter and I had him check the outputs of the IC that drives the LEDs, before and after activating cruise. The hope was that we'd find an unused output that would be used to drive the cruise LED if present. Unfortunately, no such luck.
Old 05-13-2009, 12:01 PM   #75
PatrickJohnson
Drives: 2008 Yaris LB
I'm confused. I've seen someone ask if this can be done on an 08 Yaris LB with no cruise light on the dash, but haven't seen a solid answer. provided I tap the ECM as mentioned earlier, I should be able to do this mod just with no indicator, correct? The ECM cruise programming is there regardless, right?
PatrickJohnson is offline   Reply With Quote
Old 05-13-2009, 12:46 PM   #76
Correct. Nickhjort has proven that it will work on 07-08 Yaris which do not have the indicator, by directly connecting the the ECM.
Old 05-13-2009, 04:59 PM   #77
Treyz
~ ambient one ~
Treyz's Avatar
Subscribed
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 05-13-2009, 10:28 PM   #78
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
I used to have a Pontiac with cruise control and no indicator lights. In my experience, there's no light actually needed - it's quite obvious whether the cruise is on or off simply from how the car behaves. As for the "Set" light, you'll know immediately if the speed isn't set because the car slows down when you take your foot off the gas.
I'm going to install cruise on my '08 with the proper switch and very tidy wiring when I get around to it. The goal is to make a sufficiently tidy installation that even a Toyota tech will think it's factory, and it will take a lot of looking to prove otherwise.
However, I'm not even going to try for indicator lights. It would be nice, but you don't really need them.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 05-15-2009, 06:44 PM   #79
expo2
OK, almost have the cruise install complete. I have the 08 Yaris LB with no cruise light on the dash. I tapped the ECM a-21 connector @ position 40 and ran the wire to the cruise on/off switch on the dash.
Last question: How do I wire the new clutch switch I just installed? Does the wire from the ecm go to the clutch switch first, and then continue to the cruise on/off switch on the dash?
Old 05-15-2009, 07:17 PM   #80
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Where can I obtain one of those clutch switches? As cheap as possible please :)
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-15-2009, 11:58 PM   #81
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
expo2, no you do not put the clutch switch in series with the cruise circuit. In fact you put it in series instead of the jumper wire stated on page 21 of this "DIY" HERE
See my post...#371.
Instead of placing the jumper wire in those two slots (as shown in the pics), simply go from one slot to the clutch switch, then back to the other slot.
Try to picture your clutch switch in place of my fuse in the pictures.
I will be making my own clutch switch tomorrow and I will take plenty of pics.
Hope this helps :)
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-16-2009, 11:28 AM   #82
expo2
Dah, I feel like an idiot and then some. I don't know how I missed your original pics of the clutch switch jumper wires.
Thanks for your help.
Old 05-16-2009, 12:31 PM   #83
nickhjort
nickhjort's Avatar
No problem. Glad to help :) I will be starting my custom clutch switch here shortly. I have to go find a switch. Then I'll post pictures later this evening.
My Car Rules!
Old 05-16-2009, 05:36 PM   #84
nickhjort
nickhjort's Avatar
See post #387 HERE
My Car Rules!
Old 05-18-2009, 01:56 AM   #85
PatrickJohnson
This is the only mod I've ever done that involved the ECM, can someone kindly enlighten me as to it's location? I believe it is in the engine compartment, right?
Old 05-18-2009, 03:37 PM   #86
Sir A.Y. Atoyot
Drives: '08 5-door
Exactly - it's on the right side of the engine compartment.
Old 05-18-2009, 05:56 PM   #87
PatrickJohnson
pardon my ignorance, do you mean right as in while you are in the car or right as though you are facing the engine compartment while standing at the front of the car?
Old 05-18-2009, 06:38 PM   #88
MGargano
Drives: 2009 Yaris Hatchback
Driver's side
Old 05-18-2009, 09:36 PM   #89
Sir A.Y. Atoyot
Drives: '08 5-door
Right side of the car as you sit in the driver's seat - the passenger side, in other words.
Old 05-18-2009, 11:57 PM   #90
nickhjort
nickhjort's Avatar
Passenger's side in the engine bay. Also my clutch switch works perfectly. It truly is a frankenstein though. I will take some pics tomorrow when it's light outside. If you don't mind spending the 18 bucks, buy the stock one. It will look more professional. I may switch it out later, I just wnated to see if I could make my own :)
My Car Rules!
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
