#109 |
That's the nice thing about mounting the switches to that removable trim piece - All of the drilling mess happens on the bench instead of in the car.
#110 |
Here is my switch install showing the radio shack numbers. Note: I havnt tried this out in the dash to see if my hole position is correct!
#111 | |
#112 |
Looks like its possible with these switches that they will fit even if they dont make the hole, judging by the standoffs on the panel itself.
Yeah it fits! The switches are on a 3/4 inch circle. The center of the circle is 1 3/16 inches from the top of the panel (as measured on the outside of the panel) and 1 7/16 inches from the right side of the panel. I cut a 1 1/2 inch circle (the diameter of the cutout in the dash)from a piece of paper and laid out the switches on the paper. Then glued the paper to the panel measureing the center point of the circle from the sides. |
#113 |
toyota
would this work for any other cars..
#114 |
#115 |
toyota
nice...
#116 |
IM thinking something similiar will work for all such DBW cars.
#117 |
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
#118 |
Take a look at this thread:
http://www.yarisworld.com/forums/showthread.php?t=16188 It shows what is required to do it with and 07 or 08. Basically, the extra work is running a wire from the switches to an empty pin on the ECM. |
#119 |
Mod is in and working! The lights for CC come on in the dash and the four buttons are working. I really needed this because my feet are going numb and its hard to feel how much to press the gas pedal. Now I can do it with the pushbuttons a lot of the time. Thankyou so much for this idea!
PS The wife and everybody at work were not exactly supportive about this. "Whattaya messin' wit a bran new car fo...yo is gonna RUIN it!" You need to break through this negative energy sometimes! PPS My car is a 2009 Basic 2 door HB. Made last September. Oh and it is black in color. I think that helped.... |
#120 |
I have two sets of resistors and two sets of switches I bought that I didnt use. For $5 Ill send you a set. PM me if intereted.
#121 |
pm'd
#122 |
#123 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Hold on just a couple more days and I'll have that module installed. I just haven't had time to rip the dash again. I also have to rethink my clutch switch, the switch broke. That's what I get for going cheap :) Anyway, I'll prolly just buy the oem one. I'll put picks up when I'm done with all of this...
My Car Rules! |
#124 |
thanks i might just take you up on it
#125 |
![]() Drives: 2008 Yaris LB Auto 3-door Join Date: Jun 2009
In order to provide the on-off indicators which some folks want...rather than messing with wiring LEDS and such, why not just buy an illuminated switch button? Would that work? If so, which Digikey part number would you supersmart electronics types recommend?
I'm about to make an offer on an 07 Yaris without cruise and am MOST grateful that I stumbled on this thread! Thank you all! |
#126 | |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
