#19 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
I really don't notice it
#20 | |
(their main effort was to blame me for not pulling the clutch in in time) But maybe it had something similiar to what you describe. Thats the problem with all this gee whiz neato stuff. When it breaks its pretty hard (if not impossible) to fix. Some say they dont notice this problem so maybe theirs is working properly. |
#21 |
toyota
i-stop technology is coming in 2011..some cars in europe has it already.
#22 | |
![]() ![]() Drives: 2009 Yaris LE 5 dr Join Date: Feb 2009
Pretty subtle but you can "feel" it cut in and out. |
#23 |
Half a Bubble Off Plumb
Not at all. It's engaged to the driveline and is kept turning by the car's momentum. Indeed, if you turn the switch off with the car in gear and moving, the engine will keep spinning till the car eventually stops.
DFCO is very common in modern automobiles. The fuel cuts back in at idle power level when the engine speed gets down to some preset level just above idle. |
#24 | |
#25 | |
Tamago, the "D" stands for deceleration, so it's clear that's when it happens.
#26 |
I don't notice any throttle lag at all with my new Yaris with a manual tranny.
What was described in the original post seems like a defect IMO. It is not only anoying but, downright dangerous as well! If it was me, I would go to the dealer and report the problem ASAP. Not having access to 100% WOT on demand is a real problem as far as I'm concerened. Perhaps as previouslty alluded to in other TBW threads, the less than 100% throttle is a setting for those who drive for economy while more aggresive settings are achieved for those who drive for performance? I do know that my Celica (with a cable throttle) is set up in a simular way and will tune its self acording to your driving style. I frequently have to go for WOT, etc. otherwise, it will start to tune itself for more economy and less performance. |
#27 |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
It's just compression braking with no fuel, as the drive train is turning the engine and pumping air through it.
What gear you're in determines the RPMs that your engine is running at, which determines how much air is being pumped through the engine, which is the resistance that slows the car down. It's pretty easy to get used to judging distance and timing compression braking pretty much the same as you would with your friction brakes to the point that you use a lot less friction to slow down (and less gas with DFCO). Honestly, I've noticed the lag with drive by wire more starting out in first on a hill. The workaround for me was to give it more acceleration earlier than I normally would with a manual transmission. |
#28 | |
#29 |
sounds inefficient the way you describe it, but I'm sure Toyota considered options and built something for optimum mileage, don't you think?
#30 | |
#31 | |
I agree! Unfortunately my wifes 05 Camry does the same thing. So we went through all this four years ago with the dealer. They couldnt fix it. I think it IS dangerous or at least undesireable. But you adapt to it I guess. The safety people could declare a recall but I doubt the company could do anything about it. Some claim their Yaris doesnt do this. Id like to try one out. If it didnt boy I would say the government should issue a recall notice. But in my experience the company couldnt fix it. |
#32 | |
Spool'd
Drives: 07 yaris, 16 gen coupe rspec Join Date: Aug 2007
#33 |
#34 |
shoulda bought an R bike
#35 |
i think this deserves a captain obvious award.
#36 |
Spool'd
| Throttle lag and response | yaris-me | General Yaris / Vitz Discussion | 19 | 05-20-2017 10:02 PM |
| Blitz throttle controller | 808_Yaris | Performance Modifications | 43 | 10-22-2009 05:36 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 09:52 PM |
| DIY: Crosspost of how to get rid of DBW Lag! | Nexus1155 | DIY / Maintenance / Service | 7 | 09-14-2007 02:26 AM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 01:03 PM |
