Old 07-02-2009, 07:15 PM   #109
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
can i get a pic of the turn signal on? :) i'm considering getting a pair of these for yaris :)
Here you go Chris
Old 07-02-2009, 07:17 PM   #110
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Originally Posted by ScubaSteve View Post
Any trouble with the colour match for the Copper Orange(Tucsan Sunset)? Got the same colour on my Yari and contemplating ideas for my car when I finally get away from stock.
Hi Steve , As far as the color matching goes it really depends on
who's doing it for you , but i have not had any problem's yet , touch wood
Old 07-04-2009, 03:55 PM   #111
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
is there any DIY to put the eyelids? ... i just bought a pair and i dont know how to install them...
do i need to open the lamp? or it's installed over the lamp from the outside?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 07-04-2009, 04:36 PM   #112
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by shambala9er View Post
Just showing off mines thanks to Garm, I do not see what the big deal is about getting them painted they really transform the car. Thanks Garm.
I agree! Getting them painted locally is quick and not that expensive. You also get the best results, since they match it to your car's paint.
Here's mine Thanks Tk
No problem, Ray! Thanks for the nice pics.
Originally Posted by Treyz View Post
TK, putting mine back onto my new '09. We'll see how the look on the new headlights.
I tested v3's on an 09 and they fit perfectly. I didn't need to change the design at all. Please post more pics of your awesome Yaris!
Any reputable shop should be able to match your color without issues. Just make sure they use enough flint to match your color just right.
There's no DIY per say, since the process is very simple:
  1. Clean the areas with rubbing alcohol and let dry
  2. Stick one side of the 3M tape below each piece
  3. stick the other side on top of each lamp
  4. press firmly on both eyelids and let them set 10-15 mins
  5. Done!
Old 07-04-2009, 06:10 PM   #113
Treyz
~ ambient one ~
Treyz's Avatar
Here are v2's on my v2.0 ... I gotta admint, the curve fit's 100% beter for the base than they did on v1.0 lol ...
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 07-04-2009, 07:59 PM   #114
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Awesome work Treyz, I always wanted to see how the eyelids will look on an '09. Thanks!
Old 07-06-2009, 08:13 AM   #115
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
another question...lets say we wanted to remove the lids with little to no damage...can it be done with a heat gun or extemely powerful hair dyer? would it damage both headlight and lid?
msfire671 is offline   Reply With Quote
Old 07-06-2009, 08:27 AM   #116
nice, treyz, awesome to see how well they follow the "kink" in the 09 headlights!
Old 07-06-2009, 11:36 AM   #117
Treyz
~ ambient one ~
Treyz's Avatar
I can't tell you how many times I've taken mine off and put back on .. no problems at all. I'm running with version 2 of these eyelids which still has the base which was later eliminated for version 3.
1. Initial install
2. Removed, wrapped in vinyl, and reapplied
3. Removed for winter '08/'09
4. Reapplied for FL trip
5. Removed for trade in of '07
6. Reapplied for the new '09
AMBIENTLIFESTYLE
Micro Image
Old 07-06-2009, 03:21 PM   #118
tristan
it's been a while
tristan's Avatar
Drives: 2009 liftback
awesome! I really wanted to get some eyelids but weren't sure if they fit the 09. thanks!
tristan is offline   Reply With Quote
Old 07-07-2009, 02:42 PM   #119
Rnankoo
Rnankoo's Avatar
Drives: Toyota Yaris meteorite silver
where can you get the eyelids painted
Rnankoo is offline   Reply With Quote
Old 07-07-2009, 03:03 PM   #120
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
You can easily do it yourself. Check out www.AutomotiveTouchUp.com for the supplies. Back in December I paid $19.95 for the spray paint (12oz) and $7.95 for the clear coat (12oz). They make it real easy to get the right paint. Total shipped to my door is $36.23. Color match was spot on. Look back through this thread for some of my other posts around the December, January timeframe. I have some pics posted and how I prepped them.
Good luck!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 07-08-2009, 09:22 AM   #121
msfire671
msfire671's Avatar
1. Initial install
loooks awesome!
but how do you remove it and not damage it? my brother put it on for me but it looks a bit off..the way im looking at yours and everyones it looks flushed with the hood...thats the look im going for..
I got mine painted for $80.00..
so fellas...some tips to removing please!
Old 07-08-2009, 06:13 PM   #122
Treyz
~ ambient one ~
Treyz's Avatar
loooks awesome!
Heat is the trick to making the double sided tape easier to handle. Either do it on a hot sunny day, or use a blow dryer to heat the tape up and carefully pull them off slowly.
What version of the eyelids do you have?
AMBIENTLIFESTYLE
Micro Image
Old 07-09-2009, 02:41 AM   #123
msfire671
msfire671's Avatar
i got the ones from garm!
thanks for the reply.
Old 07-09-2009, 06:33 PM   #124
Treyz
~ ambient one ~
Treyz's Avatar
Lol .. yeah, the ones that Garm sells are from TK ... probably Version 3's then.
AMBIENTLIFESTYLE
Micro Image
Old 07-14-2009, 02:56 AM   #125
msfire671
msfire671's Avatar
got it on...gotta fix one side though..its a pita to get it off!
Old 07-15-2009, 11:46 PM   #126
canadian_princess
canadian_princess's Avatar
Drives: '07 Yaris Sedan 'S'
Send a message via Yahoo to canadian_princess
Originally Posted by drbilal View Post
nice! my car only sexier! i need the grille and the eyelids.
canadian_princess is offline   Reply With Quote
The Official "Bambo the Yarisworld Traveler" thread (V1) nemesisz Off-topic / Other Cars / Everything else Discussions 3 11-08-2008 11:24 PM
I can't seem to find the thread with the pics of the '08 brochure, help? Jailbird General Yaris / Vitz Discussion 1 09-11-2007 09:40 PM
Sterio Pics Thread BlueFlash Off-topic / Other Cars / Everything else Discussions 0 06-08-2007 05:55 PM
