#145 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
if you are standing in front of the car looking at the engine bay, it is attached to the firewall in the upper left corner
#146 |
And to answer the next question, here's the location of pin 40:
#147 |
![]() ![]() Drives: 2009 Yaris 4dr Sedan Join Date: Mar 2009
OK.
looking at the engine bay and now understand the diagrams.... Since it's too dark out and my wife's scion is in the garage, I will attempt this at a different date. Thank you all for your input...i hope this works. |
#148 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Where's the engine bay??
![]() just kidding ![]() I have the factory cruise, but if I didn't, I'd probably try this mod. CT Scott is one of the best with electronics in this forum!!! |
#149 | |
![]() And here I thought they ran by magic. Revsson, I am very fluent in sarcasm....... From all the posts I read, CT Scott knows his stuff. I now have to get the courage to mess with the ECM and get the cruise working. I am far more comfortable in a room full of servers, the car stuff is a little daunting, when dealing with an ECM! |
#150 |
I had the Yaris out this weekend for a trip to upstate NY and back. (about 250 miles each way) So the CC mod got a good workout. It worked very well indeed! The car got just about 40 mpg when I set the speed on 70 mph. I did the four switch version which gives you plus one and minus one mph at the touch of a button. It came in very handy and I recommend going the four switch route if you install this mod. Getting the Radio Shack really mini switches made doing the four switch really easy...
#151 |
![]() Drives: Blazing Blue 2007 3dr HB 5MT Join Date: Jul 2009
I have been looking for a cruise control solution for a while, I am glad I found this thread
I have a 2007 Yaris 3dr Liftback with 5 spd MT, if I can't see the lit icons that you showed in the first few pictures does that mean I can't perform this DIY? |
#152 |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
It just means no indicator lights - the actual cruise will work fine, if properly connected.
#153 | |
http://www.yarisworld.com/forums/showthread.php?t=16188 |
#154 |
![]() Drives: 08 liftback 5 speed Join Date: Jul 2009
Here's how I did my clutch switch. I used a SPDT submini roller lever switch, Radio Shack # 275-0017. I superglued it in place on the metal bracket.
#155 |
Thanks for those of you who responded to my question. I am thinking about doing this mod this weekend. I will update on how it turns out.
#156 |
Does anyone know the Toyota Part Number for the dash panel next to the ignition switch? (the one I put the switches in for the CC) Im thinking it would be handy to have in case the car needs warranty work!
#157 |
#158 |
Thanks much appreciated!
#159 |
55446-52060-BO is $22 BTW.
#160 | |
#161 | |
351 to 426 ohms for the one between set and resume 819 to 1001 ohms for the one between set and cancel For the two switch method, the range for the resistor for the Set switch is from 567 Ohms to 690 Ohms. Any value in that range is fine. I would just stay at least 10 Ohms from either end point. For the clutch switch, that is correct that the 07 and 08's don't have the clutch cruise switch connector, so you do have to hardwire to connector in the under hood fuse panel. |
#162 |
is there one spot in the firewall where i can thread through the ECM wire from the switches and the two wires from the cluth cruise switch ? being that they are on opposite sides
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
