#73 |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
It won't void warranty unless it IS the cause of the damaged area to your car. But you can always take the bar off before going into dealers to check if something near the rear was damaged....
Seriously, all in all, TRD bar is the same as the UR that Garm sells.....lol I didnt notice a difference w/ my TRD vs Garm's UR bar...i just wanted ONE TRD part on my car :P |
#74 |
Same reason why I bought a TRD radiator cap.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#75 |
Heart Up! Vitz
#76 |
![]() ![]() Drives: 09 Yaris hatch, Meteor Metal Join Date: Dec 2008
well, i have no damage to the area.
i just dont want to order the TRD suspension stuff, and have kendall jack my car up and see that i have added a component, or modified from factory spec. and void the warranty that would be otherwise kept intact installing TRD components by a toyota dealer. |
#77 |
Heart Up! Vitz
Well, most mechanics dont care what you have inside/outside the car....its those stupid service people that get you setup for a check-up that whine like little girls about non Toyota aftermarket parts...
I mean....there is a front sway bar on the Yaris, would a rear sway bar cause so much damage/ void warranty? Nope, not at all.... Usually adding components to engine bay or modifying movable suspension parts voids warranty ie.... aftermarket lowering springs, coilovers, struts/shocks, etc.... a simply 19mm bar? They're b.s you if they say anything, honestly.. |
#78 |
![]() ![]() Drives: Yaris 09 T-spirit 1.33 Join Date: Jul 2009
how will this effect the ride??
forget how well the road holding is (its hard but try) how will the car drive in normal driving speeds in the city, and over bump roads?? is there a front sway bar too? |
#79 |
^ I don't notice any difference in a straight line, only in turns and against crosswinds.
There is a front sway bar available in a 24mm size, made by AOE.
#80 |
Heart Up! Vitz
Our cars already have a front sway bar...its 22mm or 23mm last i read somewhere when they measured it.
My experience SO FAR, driving/owning it for 7 days straight......it doesnt make a difference on bumps, only your tire psi will make a difference w/ that~ Mine are at 42 psi so i feel everything :P Like cali yaris has said, only differences noticed during turns and big SUVs passing you up on freeway..... |
#81 | ||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
-Jen <3 ![]() Quote:
#82 | |
IMO without the sway bar, the rear suspension seems much too soft. With the sway bar, it no longer seems like you are driving a boat. ![]() To me, it simply makes the car more fun to drive.
#83 |
and what does the upper front strut do?
in event of an accident the rear sway bar can cause more damage IMO cause if you get hit on one on the wheel the other side is effected, Am i right or not? cheers |
#84 | |
It can be argued that a rear sway bar can possibly prevent some damage as it strengthens the whole rear axle/suspension assembly. |
#85 |
thanks a lot i'm new to yaris i had it only for 2 weeks and i find the handling very good maybe cause its lowered on the tte, still i say my alfaromeo 156 handles better but for what i paid for its very good
#86 |
![]() ![]() ![]() Drives: 09 3Dr Manual Join Date: Jul 2009
#87 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
#88 |
Not really... I just like spending the big bucks where it counts. Spending 300% extra on a part that says "TRD" and that won't even be visible most of the time is not my idea of a good investment.
Sorry for the ![]() Getting back to the UR sway bar, I have been using it for a couple of months now, and I must say it is one of the best handling mods you can make, along with lowering springs.
#89 |
![]() Drives: 08 Blazing Blue LB Join Date: Jul 2009
Thanks cali yaris, just installed my 23mm sway bar.
#90 |
![]() Drives: 2008 Yaris Liftback Join Date: Jan 2009
Thanks garm, just installed my 19mm sway bar and it makes a HUGE difference. I can't believe what a difference this makes! 19mm is just perfect for my driving style, and you cant' beat the price.
Thanks to everyone that left their opinions and recommended this upgrade! |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 02:05 PM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 03:26 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 02:46 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-06-2008 12:37 AM |
| DIY - TRD rear sway bar | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-20-2008 02:21 PM |
