Old 08-12-2009, 09:44 AM   #19
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Another good point noted above.
BTW...why does putting a supercharger on a 4cyl car automatically mean that you actually know something or use common sense for that matter?
DerFlosser is offline   Reply With Quote
Old 08-12-2009, 01:01 PM   #20
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
There are tools called belt tension gauges. They are either generic ones that measure torque in ft lbs or in lbs or they are manufacturer specific ones. The mfg specific ones are calibrated for a specific amount of force. You press the spring loaded gauge against the belt and read the scale.
I personally don't own one. For something like the spec above, I press against the center of the belt span with one finger and look for about that much deflection.
Sweet thanks for the info. Further to this, I went to my local PartSource and asked if they had any belt tension gauges, and the guy there looked at me like I was an alien and told me there was no such thing.
I'll try the finger press thing and see.
devinlamothe is offline   Reply With Quote
Old 12-14-2010, 11:32 PM   #21
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Where can I find the Serpentine Belt Routing Diagram?
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 12-14-2010, 11:46 PM   #22
Old 03-20-2011, 04:15 PM   #23
kdogg
Drives: Blazin' Blue Yaris Liftback
help?
Any guidance on this issue would be appreciated. I have spent two hours trying to loosen the bolt at the bottom of the alternator to no avail. I have tried some pb blaster as well. I have nothing to show for my effort except sore hands. Does anyone know the trick to getting this bolt loose? The space is really awkward to get good torque so I tried a universal extension, but am still having no luck. The replacement belt only cost me $11 but paying someone else to replace it is starting to look pretty good.
kdogg is offline   Reply With Quote
Old 03-20-2011, 05:30 PM   #24
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
^^ Do you have a breaker bar?
Old 03-20-2011, 07:45 PM   #25
Klink10
Klink10's Avatar
It will come loose. Initially I had to use a 1/2 " drive and move the ac line bracket. Now a 3/8 inch drive gets it.
Old 07-01-2011, 09:09 AM   #26
bankrobber
Drives: 2007 Yaris Hatchback
What size socket is the bottom bolt? 14 seems like it is slightly loose. I cant find my 5/8 socket to try. Also have a problem getting a 1/2 inch drive ratchet in there and being so tight I dont think 3/8 ratchet will break it loose.
Any advice on breaking it loose? I wish I had air ratchet to use.
bankrobber is offline   Reply With Quote
Old 07-01-2011, 09:40 AM   #27
It's definitely 14mm, as I had mine off last weekend to install my supercharger. I used a 3/8" ratchet with a piece of pipe on the handle for more leverage.
Old 07-01-2011, 09:59 AM   #28
bankrobber
Thanks gonna go give it a try. Got 114K miles on my 2007 and belt looking tired.
Old 07-01-2011, 11:13 AM   #29
bankrobber
Done. Very simple job. Not as easy as my Dodge Ram. Kinda a PITA with a sideways engine. Think I got the tension good. Just a FIY found the same belt on Amazon for 11 dollars after I already bought one from Autozone for 20 w/tax with 3 year warranty
Old 07-17-2011, 11:24 PM   #30
othater
Drives: 07SedanS06Taco
Whats the recommended belt brand and best place to buy it.
Thanks
othater is offline   Reply With Quote
Old 07-18-2011, 04:35 PM   #31
bankrobber
In the South I buy from AutoZone. They always honor the lifetime warranty with no reciepts. Napa or PepBoys is a good place to buy also.
Use Part Number: 5040465 Dayco Brand
Old 07-18-2011, 04:59 PM   #32
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
I think this is done and gone, but I just wanted to say that I recently did this to my Egg. She has about 90K on her and needed a new belt. The bottom bolt is on there REEEEALLY good. I had to use a socket wrench and put a tube on the end to extend the fulcrum and had to make sure the socket I was using was the exact right size.
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 07-23-2011, 04:57 PM   #33
othater
Thanks Bankrobber for the reply, I will go with Autozone with the 3 year warranty.
Old 02-23-2012, 10:42 PM   #34
othater
I replaced the belt going on 6 months.
Had to tighten the belt at least 5 times due to screeching.
Seems like the belt stretches a little every time.
(I marked the original location of the bolt)
Belt looks good, maybe this Dayco is just cheap or defective.
Probably will see if I can return it under warranty.
Are the gates any better or just go get the OEM from the dealer (on-line)?
Can someone tell me what the actual torque for the two bolts are?
Thanks
Old 02-27-2012, 06:59 PM   #35
othater
Got a replacement serpentine belt.
Still a Dayco but a better quality one. Store would only give me credit for the same brand.
Originally went with the part number above. Didn't know they came in different grades.
So far so good.
Sure was easier the second time replacing.
Old 04-08-2012, 05:58 PM   #36
Illryion
Just used this guide - thanks all. Easy Peasy.
Illryion is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
