Old 11-15-2006, 11:57 PM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
Any non-Dynamat sound dampening?
Has anyone tried any non-dynamat sound dampening products; as in non-automotive stuff.
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 11-16-2006, 12:17 AM   #2
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
i haven't my friends have but it is meant for larger spaces rather than a hatchback so i guess the automotive stuff works better
who says it would work though
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 11-16-2006, 12:35 AM   #3
Lowfront
Drives: Yaris Sedan
you mean for a room in the house?
Lowfront is offline   Reply With Quote
Old 11-16-2006, 12:35 AM   #4
johnnyfive
johnnyfive's Avatar
you can get a roofing product called "peal-n-seal" it is basically the same stuff as the cheaper dynomat type products, except even cheaper :)
i have never used it, and personally would never think of puting it in my car, but many many people have, and they usually call it a great cost saving success...
johnnyfive is offline   Reply With Quote
Old 11-16-2006, 12:36 AM   #5
johnnyfive
johnnyfive's Avatar
sure, get the stuff you would put in a studio, and put that over your dynomat ;)
Old 11-16-2006, 03:41 AM   #6
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
I had rooled roofing material called peel-n'-seal in my truck.
Works perfect but has a stronger odor then dynomat that seems to last a bit longer. But after a couple weeks it was gone.
I only got a slight hint of odor on the hottest days.
Prep/clean all the surface that you want to cover and use a heat gun to conforn it to the contours of the area.
Works fine and is a fraction of the cost of dynomat
Old 11-16-2006, 06:51 AM   #7
vodkalush
I drive a yarrrris
vodkalush's Avatar
sweetness, thanks for the info guys. its exactly was I was looking for. I'm gonna cost out each option; when i decide to do it I'll be posting a DIY...
the road noise is driving me crazy!
will work for parts
Old 11-16-2006, 07:56 AM   #8
jcove
jcove's Avatar
Drives: 2011 Rogue
I haven't tried it yet myself, but I've heard that the closed cell foam(looks like a black rubber type material) that you can get from places like Home Depot or Rona works. I've also heard, again no experiance, that you can use the soundproofing insulation that is usually used in the inner walls and ceiling/floor of a house. It's fire rated and it's a sound dampening material. It's yellow instead of the usual pink insulation. I'm not sure if anyone else out there has tried this. Also using an open cell foam, using spray glue to fix it, on the pannels will help with any rattles or squeeks. This one I can vouch for from one of my other cars. I haven't had a chance to use it in this car yet. Try searching some of the other automotive forums and you may find something.
jcove is offline   Reply With Quote
Old 11-16-2006, 01:34 PM   #9
Lowfront
Drives: Yaris Sedan
If you really want to get rid of road noise save up and do it right...
http://www.secondskinaudio.com/cgi-b....cgi?pg=1&p=ps
The pro version of that stuff is absolutly incredible, I've done my front doors and trunk completly and its amazing. I can have my JL10w6v2 sub up as high as it goes and if you step outside you can not hear it at all. Just the wind trying to escape
Old 11-17-2006, 07:39 AM   #10
jcove
jcove's Avatar
Drives: 2011 Rogue
I was looking for this. I've heard wonders about it. It works as good or better(much better from what I've heard) compaired to Dynamat.
Old 11-18-2006, 02:33 AM   #11
spkrman
Drives: 1
second skin is great stuff :)
Isuggest a combo of closed cell foam and peel n seal for the most effective solution for the $.
Old 11-18-2006, 03:13 AM   #12
marvinng
Drives: AE86, NCP91
i've used profoam sound deadening sheet, which is less expensive and works well. i bought it at a local automotive store.
http://www.proformproducts.com/en/pr...g/?category=53
marvin
marvinng is offline   Reply With Quote
Old 11-18-2006, 03:32 AM   #13
spkrman
Drives: 1
yea itsall the same stuff
Yaris Squealing Sound Yaris General Yaris / Vitz Discussion 19 01-18-2010 11:58 PM
Capacitor for sound system??? ECHOKnight2000 In Car Entertainment + Electronics (audio / video / alarm) 12 11-01-2006 01:30 PM
Post Your Sound System Pictures DJ_Trizzak In Car Entertainment + Electronics (audio / video / alarm) 17 07-25-2006 11:56 PM
dynamat or cascade? twixt In Car Entertainment + Electronics (audio / video / alarm) 1 07-20-2006 07:26 AM
5 Door people warping sound? lowkey General Yaris / Vitz Discussion 13 06-27-2006 07:29 PM
