View Poll Results: When did you experience your first mechanical failure?
None yet! Though few miles... 13 22.81%
None yet! > 20k miles 21 36.84%
None yet! > 50k miles 14 24.56%
None yet! > 100k miles 0 0%
< 20k miles 6 10.53%
< 50k miles 2 3.51%
< 75k miles 1 1.75%
< 100k miles 0 0%
< 150k miles 0 0%
< 200k miles 0 0%
Voters: 57. You may not vote on this poll
Old 08-19-2009, 11:24 PM   #19
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
Scary. I hate to see how much that will cost to fix. What is that red V thing? TRD?
ellenbetty is offline   Reply With Quote
Old 08-19-2009, 11:27 PM   #20
Tamago
Tamago's Avatar
Drives: UZJ100
$1200
Old 08-20-2009, 07:12 AM   #21
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
$1200's getting off cheap for a thrown rod these days.
Old 08-20-2009, 07:45 AM   #22
roxy1
Drives: 2014 yaris 5 speed
7 out of the 43 votes had mechanical failure before 50k miles? not good. i hope many of those were self induced.
roxy1 is offline   Reply With Quote
Old 08-20-2009, 07:48 AM   #23
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
dont worry.. if you drive your car like a jolly ol green peace lover and on top of the maintenance, you shouldnt see any problems
Its a Chao!!!
Old 08-20-2009, 08:58 AM   #24
Tamago
Tamago's Avatar
Drives: UZJ100
that was a complete engine with all accessories (except AC compressor) and a transmission attached.
the odometer on the car it came out of showed 2,985 miles
i got really lucky. http://www.gardnerautoparts.com/
Old 08-20-2009, 09:32 AM   #25
Yaris Hilton
Smile
It's silly to think that a poll on a forum like this tells you anything meaningful about the reliability of the car. It's self-reported, and people who've had a problem are the ones most likely to reply. And we're a small segment of Yaris freaks anyway. You'll have to look at the larger surveys like J.D. Power, Toyota's, etc. for any sort of meaningful numbers.
Old 08-20-2009, 09:39 AM   #26
Tamago
Tamago's Avatar
Drives: UZJ100
ironically, the xA has been the most reliable car in the united states for 2 years now..
also held its value better than almost any car in its segment. 3 years after purchase (for $12,500) a pristine xA with my mileage could still retail for $11,200. try finding any other car that held it's value that well
Old 08-20-2009, 10:27 AM   #27
markitect
Drives: Yaris
No mechanical problems, although the rear defroster had one line that wasn't working and I had the dash rattle. I don't really count those as mechanical failure.
markitect is offline   Reply With Quote
Old 08-20-2009, 10:59 AM   #28
roxy1
criteria wise, this poll would have about as much validity as the JD Powers surveys (especially the initial quality surveys, of which the methods they use to collect their data are so very useless, imo).
what skews it is that a disproportionate percentage of YW members modify their cars vs the general population of yaris owners, since im certain 99+% of them never give any thought to modifications.
Old 08-20-2009, 12:59 PM   #29
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
over 22k in my '07 and nothing yet /knocks on wood...
Old 08-20-2009, 01:03 PM   #30
craigq
Drives: '07 Yaris, '12 GLI
Right front wheel bearing went at approximately 8000km/5000miles.
craigq is offline   Reply With Quote
Old 08-20-2009, 01:03 PM   #31
Tamago
Tamago's Avatar
Drives: UZJ100
do you have aftermarket wheels?
Old 08-20-2009, 02:23 PM   #32
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
does a flat tire count lol? About to hit 4,000 miles and am getting the low tire pressure signal =( I got it a few days ago, filled the tire with air, was ok for a day, now its back! Guessing there must be a hole.
wiirenet is offline   Reply With Quote
Old 08-20-2009, 02:26 PM   #33
tomato
tomato's Avatar
low pressure signal? wow. Really? Didn't know the Yaris could do that.
Old 08-20-2009, 02:38 PM   #34
wiirenet
wiirenet's Avatar
Yea, the one that looks like (!) manual says "Indicates low tire inflation pressure" that basically means "indicates flat tire" right?
The thing is, none of the tires look flat. There's no bulging at the bottom. But when we tested them the first time, one did have a significantly lower pressure so I don't think the light is malfunctioning... but like I said, nothing looks flat.
Going to a mechanic today that can hopefully find and patch a hole, I don't want to buy a new tire!
Old 08-20-2009, 02:59 PM   #35
Yaris Hilton
Smile
That signal looks like a "moon" smiley.
It goes off when the tire pressure gets down to about 25 PSI, which doesn't look "flat" but is certainly too low. Our basic TPMS system doesn't tell you which tire is down, just that one or more is, and it doesn't affect it when the tires are rotated.
Old 08-20-2009, 07:36 PM   #36
craigq
Nope, stock 15" factory steel wheels.
Nothing like a rod through the engine block though
Yaris 2001 - serious problem adnanmalik General Yaris / Vitz Discussion 10 06-19-2006 08:59 AM
