#19 |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
For the next time you need to transport your kitty, buy a cat carrier and put a towel inside. They make cardboard carriers that shouldn't be too expensive.
Can you post a photo of the offender so we can admire it? |
#20 |
well going back to school. I think what you are smelling is the ammonia smell in the urine. You could try a mixture of oxyclean and water and spray and scrub it. Its got stuff that will neutrilize it. Since its more of a base. it should do the trick. Then take a wet dry vac and suck out the water. And then let the seat air dry for a few days. Its very simple to take the seat out only 4 bolts
#21 |
If the seat is removed and the car is powered on while the seat is absent, you will log a bunch of codes in the SRS system (and the SRS light will stay lit). The codes can fairly easily be reset by following a procedure that involves connecting and disconnecting a jumper a bunch of times. If you are going to remove the seat It is a easier to disconnect the battery first (and leaving it disconnected until the seat is back in) to avoid having to deal with resetting the SRS. And, yes there are a few cables that have to be disconnected to remove it.
#22 | |
aka Eleni
Drives: 10 Yaris LB Auto- Blazing Blue Join Date: Nov 2006
#23 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
Good luck.
#24 | |
![]() ![]() Drives: 09 Yaris Liftback Join Date: Jun 2009
#25 |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
Yanno, I don't think anyone asked this...
How's kitty adjusting? She doing well in your home?
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
#26 | |
Now, she can't stop bothering me when I'm home! I swear she's part dog! She insists upon being in whatever room I'm in, constantly getting underfoot (I couldn't tell you how many times she's been kicked or stepped on cause I didn't see her), and will not let me just sit on my couch by myself. She has to be either on my lap or right next to me getting kanoched and cuddled and petted. Actually, I'm not sure which is worse, my cat or my boyfriend..........
#27 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
I kept a cat for a few months for a friend of mine and moving the cat was a big deal (she didn't pee on my seat but she scratched the hell outof us when we put her in her pet carrier) but after a few days at my place she adapted, eventually resumed her normal cat life (going up on the roof, bringing back birds at doorstep in the morning from time to time - which I could really have done without, but what can you do, a cat is a cat). She also knew when I was coming back from work, came right back when she heard my car. When I had to give her back to the friend, as agreed, she again hated being moved, again acted moody for a few days, but eventually settled. |
#28 | |
#29 |
#30 |
The trick to getting a cat into a carrier is to leave it lying about so that the cat gets used to seeing it. They will even go inside by themselves to explore after a while. That way they won't get alarmed when you put them inside (until you close the door
).Amity looks like a sweetie. |
#31 |
![]() Drives: 08 Red Yaris LB Join Date: Nov 2008
I've ordered a product called Auto Vaccine that is Chlorine Dioxide. It is a powder that comes in a cup that you add water to, and it produces a chlorine type gas that permeates all of the porous surfaces inside the car and eliminates all bacteria, mold, and mildew. Most smells come from the waste of those three things. I have not received it yet, but I will this weekend. Once you set it off, you have to leave the car alone for up to 12 hours. You cannot get in it while the product is working, as it causes respiratory damage. After the product has finished, you simply roll down the windows and air it out for several minutes. Then it is ok to drive. It is enviromentally friendly and approved by the EPA. Look it up using Google and come to your own conclusions. I am trying to elimate a moldy musty smell that started when I left a window down in a rain storm. I will get back and tell you how it went.
#32 |
Half a Bubble Off Plumb
Yeah, Amity is a pretty kitty!
I love cats! We have 4. |
#33 |
#34 | |
USAF_SrA_E-4
You know what you should do?? take it for a spin and roll ur window down and toss the cat out the window LOL I hate cats to
#35 | |
#36 |
I'll take the one cat that I have, and have the rest of your 10 animals be dogs... We have a weimaraner now, but I'd like to add more to the "pack".
| Front seat modification. Increase thigh support. | PetersRedYaris | DIY / Maintenance / Service | 36 | 08-22-2018 02:37 PM |
| front seat room | Bigdaddy727705 | General Yaris / Vitz Discussion | 9 | 10-30-2013 12:26 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 04:30 PM |
| front seat removal/reinstall | mark schofield | DIY / Maintenance / Service | 2 | 01-25-2009 08:29 PM |
| FS: Extra Set of Fat Cat Front Bumps Stops | Galavoxx | Items for Sale by private party | 1 | 07-03-2007 09:58 PM |
