Old 08-21-2009, 02:18 PM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Help! Tein S-tech with 195/55/15 will it rub??
Hi all,
My ride is currently with Tanabe NF spring, i still find it not low enough for my car wheel set-up. Will prefer a slightly lower than NF without any chances of getting the rubber rub on my fender.
Is Tein S-tech lower or Tanabe DF lower? I read many reviews on the Tanabe DF with lots rubbing issue. Pls help as i'm considering between this 2 brand of springs.
Questions:
Tein S-tech lower or Tanebe DF lower--------=
Tein S-tech harder or Tanebe DF harder------=
Which one will rub less-----------------------=
Thank you if anyone could share with me on the above questions.
My current rims is: SSR Type-F 15x7 offset 42.
Tyres: Yokohama A-drive 195/55/15
Hub spacer: Rear 13mm
Spring: Tanabe NF spring
evo165 is offline   Reply With Quote
Old 08-21-2009, 02:21 PM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
it will fit perfectly fine Those rims/tires on DF will not rub also...
I cannot tell you which one is harder but im pretty sure DFs are lower
Both of them will not rub with that tire size and 42 offset
Its a Chao!!!
Old 08-21-2009, 02:51 PM   #3
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I believe that the S. Tech's are just a tad stiffer
Old 08-21-2009, 02:54 PM   #4
The S.Tech's are both lower and stiffer than the DF's.
Old 08-21-2009, 02:58 PM   #5
The S.Tech's drop the LB 1.9" all around and have spring rates of 3.0kg in the front and 3.5kg in the rear. The DF's drop the LB 1.6" in the front and 1.8" in the rear have have spring rates of 3.0kg in the front and 2.2kg in the rear.
In terms of springs, I would get the S.Tech's first (which I do have btw), the TigerTec's (avaible from Micro Image) second, and then the rest of the market.
Old 08-21-2009, 02:59 PM   #6
TheRealEnth
Beast
are you sure?? i got about 1.8''front 2''back on DF's
Its a Chao!!!
Old 08-21-2009, 02:59 PM   #7
The S.Tech's shouldn't be a problem with your rims and tire set up.
Old 08-21-2009, 03:00 PM   #8
Those were manufacturer specs.
DF's: http://www.tanabe-usa.com/springs/sp...tions.asp?id=1
S.Tech's: http://www.tein.com/price/toyota.html
I probably got at least a 2" drop on my sedan from the S.Tech's.
Old 08-21-2009, 03:01 PM   #9
TheRealEnth
Beast
none of them are goign to be a problem
Its a Chao!!!
Old 08-21-2009, 10:59 PM   #10
evo165
evo165's Avatar
Thanks guys for all opinion and advises. I shall go on and try the s tech for something different from my current NF.
WTB: Tein S. Tech rear springs jkuchta Willing to Buy by private party 4 03-06-2009 03:00 PM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 05:16 PM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 10:22 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 06:08 PM
