#73 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
So I know the sizes of the gauges that are going to be used in the pod but I can't seem to find a good way to search for specific gauges in specific sizes.
Are there any good, well-established sites that sell gauges that anyone can recommend? |
#74 | |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
![]() I crush you like tiny clown car, because you are clown, yes? |
#75 |
jeg's/summit
#76 |
This piece gets mounted on top of the glovebox door. It will not fit RHD cars, but the piece I sold them originally will.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#77 |
our unit will not fit a RHD. and i used the one i got from tk to make my original.
#78 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
So will it be glued-on, or will there be screws like the JDM?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#79 |
here again..
ok, so for the mounting we have two options, 1- the unit could be mounted just like the original RHD with 4 long self tappers, in which case will be shipped with a template that you lay down on the glove compartment before pre-drilling, or 2- 1" "L" shape brackets mounted to the inside of the pod line it up and then drill the self tappers, whatever the case may be we'll choose the easiest and quickest way and post pics and instructions...
Don't be threating me with a good time!!!
#80 |
Couldn't you use 3M double sided tape in order to avoid having to drill up your OEM parts? I'm pretty sure the tape would hold and it is very thin (~1mm). http://bit.ly/3Hc8w3
It would just be a matter of adding an extra surface on the back in order to hold more tape...
#81 | |
also to fix to the dash . |
#82 |
#83 |
Smart arse ,it would cheaper to fly over there to live .
#84 |
Cheaper monetarily....but it'd end up costing you your soul, just like the rest of us.
#85 |
here again..
gents, you CAN use double sided tape to hold it in place however, the only problem I see (trust me I deal with this issue all day, I'm a sign maker lol) is that after you put the tach and the gauges on it adds a lot of weight to the pod and it might fall off (even with the 3M stuff which is pretty strong) beside the weight issue there's also the problem that even if you find a double sided tape that's 1/4" wide you'll still going to have some showing from the edge of the pod, however installing it is really up to you guys how you preferred, besides you'll need to drill some holes for the wires to pass thru...(if you don want them showing of course)
#86 |
ok guys, correction, for the tach, the opening is actually 3 3/8" not 3.5, that's for the sunpro tach setting, the autometer tho is 3.5 if you have a mini monster (shift light included) otherwise is also 3 3/8, for the small the opening is 2 2/16", double check before you get a tach or otherwise you'll have to "Dremmel" the hole a little bigger
#87 |
★weeaboo★
Put me down for one, great job guys, thanks for making such a elusive part easier to find and mount to our cars.
#88 |
was my last post deleted?
#89 |
#90 |
here again..
| Triple C Design Presents........Gauge Pod collection | cruz-gsr | Items for Sale by private party | 50 | 09-21-2009 11:21 PM |
| TRD Gauge Pod | cruz-gsr | Willing to Buy by private party | 11 | 07-13-2009 01:42 PM |
| Does anyone have the glowshift a-pillar gauge pod? | Sodium Duck | Cosmetic Modifications (Exterior/Interior) | 31 | 03-16-2009 12:49 PM |
| TRD Options | S1L3N7 D3A7H | New YARIS Purchase Forum | 26 | 01-20-2009 01:52 PM |
| TRD Parts | MC-BPT | Sponsors Classifieds Area | 9 | 06-23-2007 10:51 AM |
