Old 12-11-2009, 11:54 AM   #1
chai
Go Duke!
Drives: '09 Sedan AT
Synthetic oil and dipstick?
Anyone else find it somewhat difficult to get a good reading off a fresh synthetic oil change? I did my first oil change at around 5K mark, drained all the old oil out and put in 5W30 Pennzoil Platinum (~3.3-3.4 qts) and a TRD filter. At first I was surprised to see oil splatter all over the dipstick - but have since measured twice after parking overnight in the garage. ~50F in garage, 5F outside...
Seems to read about 3/4 in the good zone (thicker, fresh oil) with thin splatters all along the dipstick.
<|L|===========|====|F|==============
Is this normal behavior with synthetic oils? It's unlikely I put in too much oil...
chai is offline   Reply With Quote
Old 12-11-2009, 01:09 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Not unusual-I've experienced the same. It will get easier to read when you get a few miles on it.
The level you indicated seems about right for the amount of oil you added.
-The Fitful One
Old 12-11-2009, 01:21 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I find it nearly impossible to get a good reading on a fresh oil change. Which reminds me, I should go check my oil level :)
Old 12-11-2009, 01:49 PM   #4
DerFlosser
DerFlosser's Avatar
Drives: Yaris
My neighbor has a Yaris and after my first oil change, I must've looked at the dipstick about 12 times and couldn't get a good reading. He walked over and smiled and said "I had the same problem...it's hard to get a reading." For a while I thought I was losing it. I have never had this problem on any other car of mine except the Yaris.
DerFlosser is offline   Reply With Quote
Old 12-11-2009, 02:31 PM   #5
Hershey
same here . Best to check it following morning after sitting overnight . May take up to 3 times to get a good reading .
Old 12-11-2009, 06:02 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's the same with any fresh oil. Let it sit for a few minutes after shutoff, wipe the stick off really well, reinsert it, and look at it in a good light. Outside in the sun is best.
Old 12-11-2009, 06:05 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^+1
Old 12-11-2009, 06:23 PM   #8
Best thing is to pour red food coloring in right after the oil change.
just kidding
Old 12-11-2009, 07:18 PM   #9
bronsin
bronsin's Avatar
Yet another reason not to use synthetic oil! Conventional oil is number one for dipstick reading!
Old 12-11-2009, 08:42 PM   #10
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
This. Even with normal oil it is really difficult because of how clear it is.
Old 12-11-2009, 10:12 PM   #11
chai
Go Duke!
Yeah, I think I went a bit overkill for a daily driver, but a higher quality filter and higher quality oil can't hurt.
Glad to hear it's not just me having a hard time reading the dipstick after a fresh oil change with the Yaris.
I'll upload the picture of how I got the factory filter off at some point, should make some good laughing material...
Old 12-14-2009, 12:28 PM   #12
DerFlosser
DerFlosser's Avatar
Drives: Yaris
my issue/concern isn't so much the ability to see the oil as much as it is the oil smudging above the actual level making it hard to read. It's almost as if the combination of tube angle and flimsiness of the stick wich makes the level appear skewed once pulled out. Kind of hard to explain though my wife's Scion suffers from the same thing.
Old 12-14-2009, 12:53 PM   #13
Yaris Hilton
Smile
I think some of it's from oil splashing up the dipstick tube and then dripping or smudging off on the dipstick.
That's one reason to wait a while after engine shutoff, another of course being to let oil drain down from the head to the pan.
Old 12-15-2009, 12:25 AM   #14
Hershey
seems like the fresh oil doesn't want to adhere to the stick . Is frustrating . Gets better over time . Then top off if needed .
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Oil spray from dipstick xkejjer General Yaris / Vitz Discussion 2 07-25-2009 03:02 AM
When should I start using synthetic oil?? trwxxa DIY / Maintenance / Service 68 06-29-2009 06:16 PM
Which mark on engine oil dipstick? The Shape DIY / Maintenance / Service 12 05-18-2009 10:19 AM
why is one side of oil dipstick different from otherside? Yawesh General Yaris / Vitz Discussion 7 01-19-2009 12:41 PM
