Old 12-16-2009, 10:04 PM   #487
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
CTScott - so the link you provided is the correct size/length for the Yaris?
Old 12-16-2009, 10:16 PM   #488
Yes, that link is from my order to Jegs. They come in packs of 5, so 4 packs gives you 16 + 4 spares.
Old 12-21-2009, 11:36 PM   #489
Originally Posted by yaris07hb View Post
New "bulgey" lug nuts from Jegs arrived today (thanks to CTScott for the tip). They've been installed and torqued to spec. The Gorilla's weren't going to fall off and there were no issues over the last several hundred miles, but I do feel better with these installed. A note to any others thinking of using these or similar wheels:
Unlike the Gorilla's, these lug nuts are 3/4" (19mm) hex - smaller than the stock Yaris lug nuts and therefore will not fit the factory lug wrench. I took an old lug nut from my original steelies and welded it to a sacrificial socket and tossed it in with my goody bag in the spare tire well.
I think a reminder is in order here - when changing to non-stock wheels always keep a set for your spare.
Pat
Good reminder. I carry an X style lug wrench that will handle the factory lug nuts as well as the Jegs ones, but I don't carry 4 factory lugs for the spare.
Old 12-22-2009, 02:31 AM   #490
jethrojallas
Drives: 2009 3dr yaris
had my yaris for a while thought u guys might wanna see it
the color is red carmine metallic
the size is 18 inch wheels with 215 35 zr18 falkens
thinking of getting it lowered and i got the system for free but changed out the subs with memphis audio
just needa get an amp and hook it all up
enjoy
jethrojallas is offline   Reply With Quote
Old 12-24-2009, 05:51 PM   #491
Kal-El
Kal-El's Avatar
Originally Posted by MR. CANTON View Post
I have TRD SPORTIVO shock and spring and well the rim is 17" x 8" wide with 235/40/17 Sumitomo HTRZ tyres
& a pimped out PUP
Wow, nice setup. Tell us what rims those are!
Old 12-24-2009, 06:13 PM   #492
YarisSedan
Drives: 08 Yaris Sedan
I can finally post in this thread...
Old 12-24-2009, 08:21 PM   #493
Kal-El
Kal-El's Avatar
Nice! Are those 16's on stock suspension?
Old 12-25-2009, 12:22 AM   #494
YarisSedan
they are 15s on trds
Old 12-25-2009, 11:35 AM   #495
Kal-El
Kal-El's Avatar
Really?? Those definitely look like 16's. For some reason they just look bigger than the stock wheel size. I'm sure the drop has something to do with the illusion.
Cool.
Old 12-25-2009, 12:09 PM   #496
YarisSedan
Cool.
I am running a 55 tire size while most people usually go with 50s with 15" rims that could be it too so the overall diameter of tire and rim combination is larger
Old 12-25-2009, 10:47 PM   #497
Kal-El
Kal-El's Avatar
Actually, the correct size is 60's. 55's work good though especially when lowered like yours.
Old 12-26-2009, 12:30 AM   #498
YarisSedan
I know. Even with 55s though i rub going over bumps. If i had to do it over again i would have just went with 50s.
Old 12-28-2009, 11:34 PM   #499
MR. CANTON
Drives: Yaris Sedan
man those rims look badass on your yaris. What brand are those
they are SPORT MAX With Sumitomo HTRZ 235 40 17
MR. CANTON is offline   Reply With Quote
Old 12-28-2009, 11:36 PM   #500
MR. CANTON
Drives: Yaris Sedan
SPORT MAX RIMS
SUMITOMO 235 40 17
Old 12-29-2009, 06:17 AM   #501
Kal-El
Kal-El's Avatar
SPORT MAX RIMS
SUMITOMO 235 40 17
Thanks
Old 12-29-2009, 11:00 PM   #502
Kal-El
Kal-El's Avatar
SPORT MAX RIMS
SUMITOMO 235 40 17
So wait a second, you have 235 wide tires?? Don't you get serious rubbing?
I don't recall ever seeing anyone with that width.
Old 01-13-2010, 12:10 AM   #503
BaknBlak
BaknBlak's Avatar
Drives: Black '07 HB A
I like that 5 door
Here's a new pic from summer. 107 degrees in Palm Springs. Still on Superiors, 17x7x39 with 205/40's on NF's.
BaknBlak is offline   Reply With Quote
Old 01-13-2010, 11:20 PM   #504
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
15x6.5 Konig Brite-Lite (+38). 12lbs.
195/55R15 Dunlop Direzza Star Specs
The wheels were purchased from Brian at Goodwin Racing.
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
