Old 12-26-2009, 01:24 AM   #19
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by Yaryaryaris View Post
I figured that. My comment was more toward the "get taller tires" drive-by comment (which I already know and isn't helpful in the slightest)
I'm already finding info on other sights suggesting the sedan has a taller 5th gear than the HB? is this true?
Also, the 5th gear from the Echo is taller (as I suspected) and might be swapped out quite easy.
I'll keep looking around.
Oh, it IS Christmas day. Is that why all the stores are closed? Shows how much I pay attention to such things...:)
I see a lot of people who auto x get shorter tires and smaller rims to increase their acceleration. I would think the opposite of larger diameter rim and combined with a larger tire you would get slower acceleration but it would make it easier on your engine once you get up to speed. Thus lowering your rpms at highway speeds if thats your only concern.
A heck of a lot cheaper than tearing out your transmission and rebuilding it or swapping in another.
Old 12-26-2009, 06:07 PM   #20
Yaryaryaris
Yaryaryaris's Avatar
Drives: 2007 Yaris HB 5-spd
Swapping out the 5th gear in a FW vehicle is often quite easy. I've done it to two other vehicles without even removing the trans. The final drive gear would be trickier.
So far I've read that the echo has a taller 5th gear (by a little) and a slightly taller final drive. The entire trans. doesn't seem to be swappable from what I understand.
Boy do I regret digging this thread back up.
I can see for Miles and Miles...
Yaryaryaris is offline   Reply With Quote
Old 12-26-2009, 11:47 PM   #21
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
The last car I had that would operate in the 45+mpg pulled 4 grand at 60mph. RPM has little to do with fuel mileage, it is how much fuel is used every time the engine rotates; not the same thing. It seems that everyone expects good performance AND high mpg in the same package; the Yaris is the best compromise I have found.
Taller, narrower tires ARE a viable solution, like it or not. Tall, narrow tires have less rolling resistance, better fuel mileage is the result. So, why isn't that helpful?
Old 12-27-2009, 12:42 AM   #22
Kal-El
Kal-El's Avatar
Originally Posted by Cosworth View Post
get taller tires...
So i take it know one here knows a damn thing about this topic?
Actually Yaryaryaris, Cosworth is on topic.
He's correctly suggesting that using taller tires (larger diameter) will create less tire revolutions to go a certain speed than the standard size. Hence, less engine RPM needed to maintain speed.
That said, it won't make as much difference as a taller final gear of course.
Old 12-27-2009, 12:47 AM   #23
Kal-El
Kal-El's Avatar
Of course the main reason why Toyota didn't put a 6th gear in is economics. It obviously costs more. And a taller 5th gear creates weak torque performance on the highway. So that's not the answer.
Most automakers are starting to put in 6 speed auto's in cars as a way to boost MPG but only in the middle and upper class cars. Econoboxes will be last to get them.
But when they do, it will do wonders for highway MPG. Yaris would certainly be EPA estimated over 42 and 45-50mpg could probably be achieved.
Old 12-27-2009, 05:33 PM   #24
Brentorius
Drives: 07 Mazda MX5 Copper Red
Oh boy, now my forum issue writing/spelling style is being graded (always a sign of critical thought on the hunt for fault finding.)
Would it do any good to proclaim "You Win!" or will this thread just keep going?
As stated before, my "Does ANYone know..." comment was directed DIRECTLY at the "get taller tires" comment (me quoting it was a clue) any other chiming in that's NOT related to transmission gearing IMHO is self proclaimed forum masters broadcasting the pecking order for said newbies (no worries, all forums have them)
Q: did my use of the word "damn" hurt someone's sensitivities?
Please, keep pecking away. I'll keep reading, and feeling fully entertained...
Or just drop it.
Not being graded, but you stated the attitude is reflective of what you have received. However, it was pointed out you made the first move.
Taller tires would help the gearing and would be a lot cheaper than replacing gears IMO
You claim to have information about the taller gears yet refuse to post it.
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 12-29-2009, 12:53 AM   #25
Yaryaryaris
That's what passes for thread clean up here? Deleting my responses?
No problem going elsewhere, this forum reeks of shit....
Old 12-29-2009, 11:34 AM   #26
TLyttle
TLyttle's Avatar
Don't let the door hit your ass on the way out...
Old 12-29-2009, 04:48 PM   #27
Yaryaryaris
so original. You're a special guy....
Old 01-04-2010, 06:14 PM   #28
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Just so everybody knows , the correct phrase is " Don't let the door hit you where the Lord split you "
Oooookaaaayy , I'll STFU now
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
gears of war 2 ROCKLAND TOYOTA Off-topic / Other Cars / Everything else Discussions 25 02-16-2009 10:33 PM
Transmission versus Gears caveatipse General Yaris / Vitz Discussion 3 09-23-2007 03:50 PM
Engine Run-on changing 1st/2nd Gears Ferret_san General Yaris / Vitz Discussion 4 09-06-2007 12:21 AM
Gears bulldogs2k Performance Modifications 17 07-26-2006 08:16 PM
