Old 12-22-2006, 04:10 PM   #1
Keymaster
Drives: Yaris '06 1300cc
sub question....
Hello!!!!!I'm new in forum and i'm finding really interesting your topics!! So i have a question about something.....Because there are no audio outs in the stock head unit can i connect a sub without an amplifier?? I search and i found that you can do this if you conect the 2 front or rear speakers in a rca adapter box and then to the sub is this works....??And Something else...The sub needs power-ground??Thank's a lot!!!!
Keymaster is offline   Reply With Quote
Old 12-22-2006, 05:48 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
uhhh
dude, you will HAVE to use an amplifier of some kind.
now, you CAN use the high inputs from your rear speakers to get a signal for the sub. i'd recommend against it, but then again i like good clean bass
Old 12-22-2006, 07:23 PM   #3
bugnuts
bugnuts's Avatar
Drives: 2007 Yaris Liftback BBP
Check this thread
Here check this thread, I did everything with the stock head unit and it sounds great (I'm not new to car audio either), some may doubt the quality but with the correct set-up you can acheive premium sound from the stock unit, but the key is good quality components (nothing generic from the auto parts store or such) You will definately have to have a Line Output Converter, these have high input (standard wire) and adjustable low output (rca connectors) out to reduce the amperage coming from the stock unit to whatever amp you have installed.
http://www.yarisworld.com/forums/sho...ght=fiberglass
bugnuts is offline   Reply With Quote
Old 12-23-2006, 12:55 PM   #4
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
Dude you should, its basic car audio information if you want ur sub to work to its potential and to thump really nice u need a amp to power it up and dude amps these days are cheap as hell and if u wanna just power 1 sub not more than a $100...
elsteverino889 is offline   Reply With Quote
Old 12-23-2006, 01:52 PM   #5
Keymaster
Thank's a lot guys for your info!!! i'm going to buy andn an amp and install it....If i have any questions i'll be back!!!!
Old 12-23-2006, 03:17 PM   #6
ChinoCharles
Drives: LB
Good call.
Sub with no amp... c'mon now people.
Old 12-23-2006, 09:47 PM   #7
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Its probably rare but there are subs with a built in amp, I believe my sub is that set up.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 12-23-2006, 09:57 PM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
there is, their called self-powered subs ; one of the guys at work has them in his golf and says they work great.
will work for parts
vodkalush is offline   Reply With Quote
Old 12-23-2006, 11:11 PM   #9
ChinoCharles
Drives: LB
Best Buy sells an Infinity 200W self-powered 8 inch that sounded wonderful. I believe it was about $200. Forgot about that option.
New Yaris Owner and a question... Toyota005 General Yaris / Vitz Discussion 4 12-08-2006 08:37 AM
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 11:27 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 08:45 AM
catalytic converter question SamDaYarisMan Performance Modifications 14 09-08-2006 11:18 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
