Old 03-31-2010, 06:46 AM   #271
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Thanks for the info changchewsoon
What valve springs are you intending to use? Regarding cams I think I leave them stock don't want to mess everthing at once
RE AJUSA bolts, heavier doesn't meen better but the quality of metal used. Do you know if they match exactly the stock bolts? I mean no rethreading etc..
RE Knife edging crank, Did you asked your tuner the reason not doing it?
Old 03-31-2010, 11:57 AM   #272
rob explained this point quite well.
I'm about to tune upwards of 25 psi, on stock crank and stock valve springs. I just don't see the need to spend money there when it's not necessary.
Old 03-31-2010, 01:37 PM   #273
Parmas
Parmas's Avatar
What fuel octane are you using Garm?
Old 03-31-2010, 01:59 PM   #274
91 with water/meth injection. Should be able to run 25 psi on pump gas.
Old 03-31-2010, 02:23 PM   #275
Parmas
Parmas's Avatar
I thought you have a better (directly from pump) octane than 91 there!
Old 03-31-2010, 05:28 PM   #276
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Stock valve springs are designed to work with the stock rev limit and the stock lift and ramp angles on the cams. If you change any of those, only then do you need to look at a heavier valve spring.
rob323 is offline   Reply With Quote
Old 03-31-2010, 05:53 PM   #277
I can get 100 down the street, and I can buy buckets of any race gas I want, but I don't need it with the meth injection.
Old 03-31-2010, 05:54 PM   #278
Correct. Although I will say we are doing fine up to 7200 so far, all valve parts are stock.
Old 03-31-2010, 06:23 PM   #279
rob323
That's good to know there's some head room left in the valve train, thanks Garm.
Old 03-31-2010, 06:52 PM   #280
don't worry if they float, I'll post it!
Old 03-31-2010, 06:56 PM   #281
rob323
Do they float/ bounce?
Old 03-31-2010, 07:10 PM   #282
Parmas
Parmas's Avatar
I thought you rev limit to 6500? Can you give more info on the 7200?
Does it increase power or remain constant between 6.5-7.2?
Old 04-01-2010, 08:14 AM   #283
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
i just got a call from my tuner that my cylinder head just came back, im gonna go snap pictures tomorrow and i'll ask him about the valve springs.
reason why the shop that was working on my head changed the valve springs is because we told him that we wanted to increase the rev limit to at least 8,000 rpm or above.
the AJUSA bolts does match the stock bolts, the only think im not able to comment is the quality until we use it.
as for the knife edging crank, i did not asked him why we do not need to do it.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-01-2010, 11:31 AM   #284
Parmas
Parmas's Avatar
Wow man 8000rpm seems too much for a 1NZFE although I wish you all success in your project. I think in your case, knife edging the crank will help you more reach that goal.
Keep us updated
Old 04-01-2010, 12:10 PM   #285
Looking forward to your dynos, that will be really cool!
@ Parmas: we have the limiter at 7200 but if you've looked at my dynos, it quits making power about 6500.
It MIGHT make power up higher with the new custom intake manifold. Next tuning session will tell us a lot more.
Old 04-01-2010, 01:27 PM   #286
Parmas
Parmas's Avatar
Yes I saw that before but I thought you got it making power till 7200 after that.
BTW I heard some ppl saying that water injection reduces power output when used. I mean if you run the same setup with for example 16psi with water injection and dyno compare it without, it will result to a slight power decrease. Is this true?
Old 04-01-2010, 01:30 PM   #287
possibly, any volume taken up by water vapor is not filled with air/fuel mixture... Not sure how big of a difference it would make, but it's a small compromise to be able to run on pump gas!
Old 04-01-2010, 01:52 PM   #288
"some people saying" means nothing to me. Show me some results and I will be very interested, although I'm not trading away the ability to run high boost on pump gas - that is way too much fun to give up!
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 12:43 PM
cali yaris built motor cali yaris Performance Modifications 83 09-04-2009 12:08 AM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 03:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 11:58 AM
