Old 04-06-2010, 06:01 PM   #73
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
yours and mine i need to bring back tomorrow to make the holes but if you want ill ship yours w/o the hole, i have a nos system and i don't know if is the same, also the fab told me that if i use the silicone that is for making gaskets i will not have any problems and i can ask him about the anodize but hell probably charge more.
cruz-gsr is offline   Reply With Quote
Old 04-06-2010, 06:43 PM   #74
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I'm willing to pay a little more for the anodizing. Please ask him how much it'll cost.
As far as the hole... I'm not sure. Might be tough to get it done around here.
I could post a pic of my fogger and compare it to yours?
Old 04-06-2010, 06:52 PM   #75
cruz-gsr
cruz-gsr's Avatar
ok do that and i can compare it to mine.
Old 04-06-2010, 08:38 PM   #76
Maitre_Te_Te
Drives: Yaris 08
Question, one side is designed for to install the 1zz throtel body and other side for intall on intake manifold but the size of the hole is biger than the yaris TB hole or the same diameter??? If this is the same, I think that the 1zz TB become like a 1nz TB!
Maitre_Te_Te is offline   Reply With Quote
Old 04-06-2010, 10:17 PM   #77
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The diameter on the 1ZZ TB is larger than the 1NZ TB. Hence the benefit of having the adapter to smooth things out.
@cruz-gsr: Here's the pic of my fogger:
Old 04-08-2010, 08:09 AM   #78
Maitre_Te_Te
Drives: Yaris 08
anubody have a new about shiping?
Old 04-08-2010, 04:33 PM   #79
cruz-gsr
cruz-gsr's Avatar
yeah they ship yesterday, for you they said i will take about a week to 10 days.
Old 04-09-2010, 12:04 AM   #80
Maitre_Te_Te
Drives: Yaris 08
ok, tanks!!!
Old 04-10-2010, 12:09 AM   #81
MGargano
Drives: 2009 Yaris Hatchback
Received mine today. This thing looks hot! Can't wait to do the install, though I just realized I'll need longer bolts or studs to bolt the 1ZZ TB and spacer to the manifold, since the OEM ones will be too short (and I snapped a stud the last time I tried this swap, so I've been running with 3 for a few months).
What are you guys planning to use in between the TB/spacer and spacer/manifold to ensure a good seal?
Old 04-10-2010, 09:12 AM   #82
cruz-gsr
cruz-gsr's Avatar
im going to use the black silicone that is desing for making gaskets its like $3 at autozone
Old 04-12-2010, 09:00 PM   #83
Maitre_Te_Te
Drives: Yaris 08
Anybody have receive her spacer and test it???
Old 04-12-2010, 09:15 PM   #84
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by MGargano View Post
Received mine today. This thing looks hot! Can't wait to do the install, though I just realized I'll need longer bolts or studs to bolt the 1ZZ TB and spacer to the manifold, since the OEM ones will be too short.
Please post the longer bolt size if/when you can. I'm still waiting on my spacer, so I can go get these before it gets here. TIA
Old 04-12-2010, 09:17 PM   #85
MGargano
Ditto. Actually, I have my TB and spacer, but I'd rather someone else be the guinea pig on this one. And I need the specs for the longer bolts.
Old 04-14-2010, 10:13 PM   #86
Maitre_Te_Te
Drives: Yaris 08
I receive my spacer... tanks. Anybody have try her???
Old 04-14-2010, 10:37 PM   #87
Maitre_Te_Te
Drives: Yaris 08
the intake side of spacer (not throtel side) is smaller tan other side, Ok but this is the same diameter taht the original throtel? If this is the same diameter, the 1zz throtel body become a 1nz throtel body...??? Anybody can explain to me please? Im not good with physic! lollll
Old 04-14-2010, 10:39 PM   #88
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
its good that someone picked this up where i failed to deliver
Old 04-14-2010, 10:47 PM   #89
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The spacer has two holes: One with a regular 1NZ diameter hole in it, and the other one with a larger 1ZZ diameter. You need to attach it so the small hole is facing the manifold and the large hole is facing your 1ZZ throttle body.
Old 04-14-2010, 11:03 PM   #90
Maitre_Te_Te
Drives: Yaris 08
Yes I know but if the hole is the same that original, what for use a larger thrtoel if you reduce de diameter. The 1zz throtel is juste to litel larger than the holl of intake manifold, so the spacer can be 2.2 ich to 2 ich, not 2.2 ich to 1.8 inch? I think :P
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 04:53 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 04:59 PM
