Old 05-08-2010, 03:32 PM   #1
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Need a "Mild" Drop (..and other stuff)
Hey folks, since acquiring the 17" rims I've been somewhat unhappy with my new 4x4 stance and would like to see the Yaris get a very mild drop (lowering springs?)
I want to maintain the ride quality and don't want to feel every pebble/rock, dips, rtc. on the road. I'm just looking for a slight drop (1" at most) and something that would not require me to replace the oem struts or need a camber kit.
Any brand of springs you can recommend and/or can recommend a reputable place where I can take the car to get it done around the GTA? I'm mechanically challenged and not really interested in DIY'ing it (no tools).
Thanks!
Old 05-08-2010, 03:59 PM   #2
Eibach Prokits for a 1" drop. These springs are what Toyota Canada installs if you get lowering springs from the dealership.
Try sending thebarber a PM. He may be still selling his.
Old 05-08-2010, 05:07 PM   #3
beZzZ
Learning & Upgrading
beZzZ's Avatar
Drives: 2006 Yaris 5 Dr HB Black
you can put TRD springs in consideration too, 1.2" drop, both front & rear.
But first, PM thebarber, it's better to deal locally.
beZzZ is offline   Reply With Quote
Old 05-09-2010, 02:13 AM   #4
toy_toronto
always toyin'
Drives: 2010 5-Dr
Thanks WeeYari and beZzZ.
I'll do a research on the eibach's and trd's to see which ones fit the bill. cheers.
Old 05-09-2010, 02:28 PM   #5
MadMax
MadMax's Avatar
By the way, those rims look great on your car!
Did you have OEM wheels on beforehand? If so, have you noticed much difference moving over to the 17s? I ask because I had 17s on mine when I got it from the dealer, so I am interested in the observations of someone who had stock rims and tires and switched over to 17s on how the handling has changed, performance differences and also what kind of effect they have had on the fuel economy...
Cheers! M2
Old 05-09-2010, 05:19 PM   #6
Billiam
Drives: '10 White Yaris 4D LB
TRDs are a mild drop with good ride quality, IMO.
Old 05-09-2010, 07:52 PM   #7
beZzZ
beZzZ's Avatar
Nice drop, what rim & tire size you currently have?
Old 05-09-2010, 08:08 PM   #8
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
I sent a PM over to barber. I've been looking for a small drop as well for a while now.
Old 05-09-2010, 10:14 PM   #9
Billiam
They are 15x6 EM7s with Toyota centers and a +39mm offset. The tire is a 205/55 ContiExtremeContact.
Old 05-09-2010, 10:21 PM   #10
Ryu
Just thought I would share, here is one of the place selling TRD sparing for descent price.
http://www.trdsparks.com/displaypart...&parts_id=1136
Eibach spring is a very good option also, it is widely used for many car manufacturer as an accessory option.
Old 05-10-2010, 02:20 AM   #11
beZzZ
beZzZ's Avatar
Yeah, trdsparks get very decent price for the TRD spring. Just the shipping for USPS is around USD $110, which is a bit too expensive. That's why I got mine from Treyz.
Old 05-10-2010, 02:22 AM   #12
beZzZ
beZzZ's Avatar
Nice rim, wish I can save up quick to get mine a set of 4 soon.
Old 05-10-2010, 03:09 AM   #13
tomato
tomato's Avatar
@ biliam : looking nice!!
Old 05-10-2010, 06:14 AM   #14
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
U CAN GET KONIE FSD'S AS THEY ARE FULLY ADJUSTABLE AND WHEN U ON THE BUMPY ROAD THEY SOFTEN UP AND WHEN U ON A SILK ROAD THEY GET HARD AGAIN FOR BETTER CONTROL
nazier is offline   Reply With Quote
Old 05-10-2010, 09:21 AM   #15
MUSKOKA800
MUSKOKA800's Avatar
Mines a sedan which has been heavily loaded several times for long trips.
My TRD springs (red) which were spec'ed at 1.25" drop are now closer to 1.5" drop after nearly two years and ~50,000 kilometers of pure enjoyment. No regrets.
Old 05-10-2010, 10:12 PM   #16
Billiam
Originally Posted by toy_toronto View Post
....or need a camber kit....
BTW, I had the alignment checked a couple of weeks after in the install, and it was spot on....camber and toe were perfect. You'll certainly not need a camber kit....unless you want more camber. I was able to get -0.9 degrees when I put everything back together...and that's enough for me.
Old 05-10-2010, 11:53 PM   #17
selling my prokits to alan1828
sorry guys
but if anyone wants my coilovers....$500 local pickup
Old 05-11-2010, 12:39 AM   #18
toy_toronto
always toyin'
Drives: 2010 5-Dr
Thanks for all the ideas and input folks
Cheers! M2
Thanks! The wheels are Enkei CDR9's. I did have the standard OEM wheels before but note that I only had the car for a week when I upgraded the rims/tires. With the 17's they feel a bit lighter to me, much better in corners and grip is excellent.. although road noise has increased a little bit. Fuel efficiency? not really sure as I've only had the car for a short time.
Your car looks hot Billiam. I'm now leaning more towards the Eibach's (1" max) though as I don't want to end up ploughing snow in the winter, lol. Apparently the Eibach also has more of a cushion/comfort feel (and drop appears "milder") compared to TRD's stiffer ride.
The pic below really shows the difference between stock and lowered... really have to get mine done. I though about ordering from tirerack.com, drop ship them somewhere in Buffalo then drive across the border to pick them up.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Question: which springs offer least ammount of drop? wholenizz General Yaris / Vitz Discussion 3 03-27-2010 09:46 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 09:37 AM
Safe Drop Distance? advocate Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-03-2009 01:59 AM
