Old 06-19-2010, 07:36 AM   #37
hwybox
Drives: 2006.5 Scion xB
Originally Posted by djct_watt View Post
I've tried it on my yaris, and also on both my xA and tC without the noise. The xB1 shares the same tranny and engine as the yaris and the xA, and the xB2 shares
the same engine/tranny as the tC. So the xB is not different.
I know thats why im on this site lol, maybe im a tard...
xB...
My car... http://www.bbsquad.org/forum/introdu...topic6868.html
hwybox is offline   Reply With Quote
Old 06-19-2010, 08:03 AM   #38
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Originally Posted by Yar Is Word View Post
Anyone remember "Clutch Cargo"?
I do!
Old 06-19-2010, 08:27 AM   #39
bankrobber
Drives: 2007 Yaris Hatchback
^if you are doing it right there should be no pop sound. You need to shift to neutral at zero load; it's the moment you're neither applying
power nor engine braking.
You need to pull it out of gear at the same time you let off the gas. If not exact on timming you will force it out of gear.
bankrobber is offline   Reply With Quote
Old 06-19-2010, 09:04 AM   #40
ddongbap
XB and Yaris trannys are different.
Old 06-19-2010, 09:12 AM   #41
Rev matching = double clutching
wrong
Old 06-19-2010, 09:17 AM   #42
ddongbap
wrong
RONG.
Old 06-19-2010, 09:40 AM   #43
Originally Posted by ddongbap View Post
RONG.
i rev match w/o double clutching daily. double clutching is for trannies w/o synchro's.
Old 06-19-2010, 10:34 AM   #44
djct_watt
Drives: 2010 NCP91 5spd
Uuuuh. . . they both use C50 transmissions. . .
Old 06-19-2010, 11:00 AM   #45
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
I've shifted without the clutch on previous cars....just to see how/that it could be done, but I gotta agree with everyone here, it just shouldn't really be done because the transmission has syncros and was designed to be shifted with a clutch, so it is most likely in the transmission's best interest to shift with the clutch.
I double clutch whenever making big downshifts, like for example if I'm going to put the car in 2nd gear at 40mph (for a fun turn) I'll put the car in neutral with the clutch out and blip it up to 4,000rpm real quick, and then it shift into 2nd gear, it's amazing the difference feeling it just "drop" into 2nd in this situation (no waiting for the syncros to work). I believe this (double clutching for big downshifts) is very good for the life of the syncros. Shifting without the clutch would do the opposite to the life of the syncros UNLESS you literally rev matched PERFECTLY every time. Which I don't care how good of a driver you are, the Yaris' electronic throttle and other environmental factors will not allow you to literally perfectly rev match every shift - You're going to be putting wear on the syncros, and it will be more wear than normal.
BuildCode is offline   Reply With Quote
Old 06-19-2010, 11:07 AM   #46
AND189
Drives: 2
ladies please
AND189 is offline   Reply With Quote
Old 06-19-2010, 11:19 AM   #47
*unsubscribing*
Old 06-19-2010, 11:21 AM   #48
AND189
Drives: 2
can't handle the heat
Old 06-19-2010, 11:25 AM   #49
bronsin
bronsin's Avatar
I do!
Animated lips. Never caught on.
Old 06-19-2010, 12:04 PM   #50
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Hey, I have a question about oil...
Old 06-19-2010, 12:08 PM   #51
AND189
Drives: 2
well this thread is about Shifting without the clutch not oil
Old 06-19-2010, 01:06 PM   #52
Kongo-Otto
Drives: '09 Yaris & '10 Auris
You can take whatever you want, even old vegetable fat is fine because i know someone who read in the internet about a guy who made 500.000 mls with his lawn mower only on vegetable fat.
Attention: Irony!
Old 06-19-2010, 02:59 PM   #53
ddongbap
O. Maybe. The gearing is different. Thats all I was getting to.
Old 06-19-2010, 03:00 PM   #54
ddongbap
I was jk about the wrong.
But you REALLY should be granny shiftin' like you aughtta.
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 08:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 02:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 11:08 AM
